5.4L 3v Camshaft Phaser Knock Noise Fix - Ford Truck Enthusiasts Forums
Old 05-25-2014, 04:22 PM
makuloco2000 makuloco2000 is offline
makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.makuloco2000 has a great reputation on FTE.
In this video I go over in detail the procedure to swap out the Cam Phaser to get rid of that annoying knocking noise at idle! It is easier than you think. The procedure is the same for all 4.6l and 5.4l 3valve engines.
Old 05-27-2014, 12:38 AM
Old 01-31-2015, 03:28 PM
I hope this helps some as this can be a very expensive repair!
Old 08-07-2015, 03:05 AM
usarmysoldier86 usarmysoldier86 is offline
usarmysoldier86 is starting off with a positive reputation.
Will the cam phasers cause the truck to run so rough that it loses power and dies? my truck started out with it sounding just like a powerstroke. check engine light came on for position sensors replaced both of them. ran great on the test drive, then when i started it back up it was running rough again. alot worse than before. i replaced all the spark plugs and put a new battery in there for good measure. still running rough. reason i changed to spark plugs because when i looked up the codes it said the code could pop up again cause of bad spark plugs. i have the money now to change out the phaser but just want to be sure that it is it. any other ideas what it might be or is it the phasers?
Old 08-23-2015, 04:35 PM
bigcanoe bigcanoe is offline
bigcanoe is starting off with a positive reputation.
Thank you for taking the time to post this!
Old 08-30-2015, 12:40 PM
sky Cowboy's Avatar
sky Cowboy sky Cowboy is offline
sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.sky Cowboy has a spectacular reputation.
Thanks for the detailed explanation and great videos.
Old 09-07-2015, 05:23 PM
flyguy108 flyguy108 is offline
flyguy108 is starting off with a positive reputation.
Great videos. I used them to change the phasers and all timing components on my truck. I actually had my laptop on the engine running the vids as I did it. Fired up an runs great. Thanks!
Weird rattling noise and ticking noise while idle nicholas116 2004 - 2008 F150 1 12-28-2016 08:15 PM
Cam phaser help Zach Carter 2004 - 2008 F150 3 03-21-2016 08:21 AM
VCT Cam Phaser Replacement Do-it-myself? Traa Biss 2004 - 2008 F150 1 12-29-2015 12:09 PM
Very Loud knocking noise on cold start up acate76 2004 - 2008 F150 2 06-22-2014 02:39 AM
4.6L Power Steering Type Whine Noise makuloco2000 Explorer, Sport Trac, Mountaineer & Aviator 1 02-04-2014 10:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
