gas smell = poor fuel economy?
I changed my spark plugs a couple weeks ago at 93K miles. They looked worn. I was expecting to see an improvement in fuel economy with fresh plugs but I have not. I have also lately been smelling gas when I start up and idling at stop lights. Doing some research I learned this is probably from the plugs not being torqued enough. I am going to pull the plugs, make sure that the seat is completely clean and re-torque them. I was just wondering if enough fuel is escaping to account for my lack of fuel economy improvement with new plugs. BTW my plugs are Autolite HT15, found them on clearance at Menards of all places.
I worded it poorly but that was my point. Before changing plugs I had been having that stumbling issue. Looking it up I saw it could be caused by worn plugs. when I pulled the old plugs they were worn, the truck only had 93k miles on it but in its last life it belonged to the city so it probably spent a considerable time idling, which would account for the wear. The initial plug change solved the stumbling issue but then I began smelling the gasoline. So now I have pulled all the plugs, made sure the threads were clean and re-torqued them and the gas smell is gone. Now to see how the mileage is on the next fill up.
79GreenMonster
4 Cylinder Engines
32
12-14-2016 12:01 AM
thefnswits
1999 to 2016 Super Duty
02-01-2006 06:07 PM
