Door Hinge Pins on a "53 F-100 - Ford Truck Enthusiasts Forums
Old 05-25-2014, 11:52 AM
jvmcc's Avatar
jvmcc jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
Has anyone replaced door hinge pins and bushings? I find new door hinge pins and bushings offered for '53 - '72 F-100 - F-350 by Mac's Auto Parts. In the Mid-Fifty Catalog I find just the pins (I assume for a "53) but no bushings. My old hinges are worn. I don't know what degree of wear is acceptable, but I can get a little less than 1/8" of play up and down at the end of the hinge arm. I'm thinking that across the width of the door, that translates into unacceptable play. Any thoughts? Pins and bushings will cost about $25. Four new hinges will cost about ten times that much.
Old 05-26-2014, 08:20 AM
jvmcc's Avatar
When the door is installed, I do not get any discernible play in the door as a whole. I'm got plenty of other stuff to do on the truck besides replacing hinge pins. (I'm posting this to myself to see if I get any viewer comments when this post rises to the top of the pile...)
Old 05-26-2014, 08:48 AM
jniolon's Avatar
jniolon jniolon is offline
jniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud ofjniolon has much to be proud of
John
not a difficult fix... knock out the old ones (the difficult part) with a pin punch. Using the proper sized drill bit, bore out the hinge... drive the new ones in... done... The new pin has teeth just under the flat head that will grip the hinge body... just use the proper sized drill bit (should be noted in your klit). No play is better than any play
john
Old 05-26-2014, 09:18 AM
jvmcc's Avatar
Thumbs up
Thanks, John.
Old 05-26-2014, 11:49 AM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
I have replaced quite a few pins...never seen a 53-56 hinge with a bushing however.
Old 05-26-2014, 12:18 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
1119-OS,midfifties number for pins.3.00 each
Old 05-28-2014, 01:27 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
If the door closes and stays closed OK and doesn't rattle on bumps IMHO I would leave it alone. I don't know how tough a job it is getting the hinge pins out but on my '50 it was a real bxxxh. Like you said you have other things to fix.
Old 08-30-2014, 09:16 PM
Outlaw56 Outlaw56 is online now
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
Two things come to mind on Hinge Pins for these trucks. The ones Mid Fifty sells are "oversize" which is fine if you want to drill out the hinge holes (both brackets) and install the new pins. I have not used their pins, but I suspect they are regular steel pins. "Macs" also has the standard size pins, but it specifies they too are just regular steel. The ones I removed when taking my hinges apart to paint them, are very hard steel. I know this because one of them was broken and I am in the process of trying to remove and replace it. In addition to being very hard steel, the stock pins appear to have a spiral groove down the outside of the shaft which I assume is to allow oil to lube the pin shaft.
I am still looking for pin options to replace my broken one and I have yet to get the pin shaft removed from the hinge.
Old 08-30-2014, 09:59 PM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
IMHO, I have been down this road before on 53-56 door hinges. Buy new hinges if you can. Replacing worn pins with the oversize pins out there are hit or miss unless you have a lot of time and energy to mess with it.
Old 08-30-2014, 10:05 PM
I hear what your saying teardrop, I did not really like the idea of using anything other than the stock hinge pin that came with the stock hinges. My hinges are all good, but one had a broken pin. If I can find that pin (original) I want to try replacing it before I invest in new hinges. If I do have to replace the hinges with new ones, are you saying rebuilt or brand new? I see Mid Fifty has "New ones" but sometimes new stuff is not as heavy as the old stuff.
Old 08-31-2014, 12:44 PM
Teardrop,
Do you have any hinge pins that were working ok when you removed them from hinges you have worked on? I have three hinges apart ready to sandblast and paint. I have one hinge the pin was broken and had a hard time getting out, but I finally got it. Im looking for one good used stock pin.
Door Hinges F150-77 Matt1966 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-10-2016 08:41 AM
Hinge Pin Bushings Gicknordon 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-19-2015 09:03 AM
successful door adjustment and hinge pin r&r maxride 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 03-21-2015 09:12 PM
Door hinge pins Wildebird 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-28-2014 04:30 PM
Door Hinge Pins? jjurva! 1957 - 1960 F100 & Larger F-Series Trucks 4 07-27-2013 03:38 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
