Fuel Problem - Ford Truck Enthusiasts Forums
Fuel Problem
Old 05-25-2014, 10:43 AM
tansdad tansdad is offline
tansdad is starting off with a positive reputation.
Fuel Problem
I recently replaced the left valve cover gasket on my 1990 2.9L Ranger and now when I start it the fuel pump does not cycle right when turning the key on. It just keeps running. Any suggestions on what I could have done or knocked loose when reinstalling the valve cover?
Old 06-05-2014, 01:23 AM
xlt4wd90's Avatar
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
No solution yet?
I would check to see if you pinched or otherwise damaged any wires around the valve cover.
Old 03-05-2016, 07:47 PM
Nancy Highsmith Nancy Highsmith is offline
Nancy Highsmith is starting off with a positive reputation.
I replaced the fuel pump and still wont start Not sure if it is a relay switch or how to bleend the lines
Old 03-06-2016, 12:46 PM
xlt4wd90's Avatar
There is a relay for the fuel pump, located under the hood in the fuse box. Does the fuel pump run for a couple of seconds when you first turn the key to "ON"? You have to listen for it; the relay will click on and off, and the pump should whirl between the clicks. Repeating this a couple of times should pressurize the lines, so no bleeding is necessary. If it's not doing this, the problem could be the relay or the pump.
You can check for pressure by going to the fuel rail, usually near the front passenger side, and look for the Schrader valve; it's like a tire valve. Carefully stick a screw or nail point against the valve core, and fuel should squirt out. That should confirm that there's pressure building up in the lines.
White motor oil Ronnief150man 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-03-2016 07:55 PM
Valve Cover Torque twigs 1961 - 1966 F-100 & Larger F-Series Trucks 4 07-16-2015 01:54 PM
Truck won't start Jess51 1999 - 2003 7.3L Power Stroke Diesel 22 05-17-2015 10:14 AM
Quick valve cover question Mac J 1973 - 1979 F-100 & Larger F-Series Trucks 5 03-25-2015 12:01 PM
Driver valve cover bolts KRDiesel 6.0L Power Stroke Diesel 3 05-28-2012 04:37 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
