Hood Hinge Brace Issue. - Ford Truck Enthusiasts Forums
Old 05-25-2014, 11:31 AM
D Sokol's Avatar
D Sokol D Sokol is offline
D Sokol is starting off with a positive reputation.
Anybody else have a bent hood hinge mount on the underside of the hood, and how did you remedy it?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
DjS
Old 05-26-2014, 08:14 AM
jvmcc's Avatar
jvmcc jvmcc is offline
jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.jvmcc has a great reputation on FTE.
The configuration of the hood cross brace on your truck is different than the one on my '53 F-100, but mine was damaged when the hood flew open on the freeway. I ended up finding a donor hood and I replaced the entire cross brace. I suspect that you will either have to do the same, or take yours off and hammer it back into proper shape and then re-install it. My auto body experience is limited, but I do not think that yours can be repaired without taking it off to work on it.
Old 05-28-2014, 01:00 PM
petemcl's Avatar
petemcl petemcl is offline
Still Learnin'
petemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to beholdpetemcl is a splendid one to behold
It looks like somebody has re-welded those braces at one time. As jvmcc suggested maybe because the hood flew open? You don't show the outside of the hood, was there any damage evident there? If not then the question is does it bother you enough to want to heat and rework that brace. Obviously the hood will have to come off for that. And you will probably end up having to repair the hood surface after you get things straightened out.
There are guys on here with a lot more body work experience than I, but if I were determined to fix it I would remove the hood, put a flat plate under the spot to be repaired, heat the brace distortion with a torch and hammer it straight. That may sound easier that it really is. Somebody else may have a better solution.
It all depends upon your build plans. If you are building a show truck then you should fix it. But if it is structurally sound with no flex and you are building a daily driver then there may be better places to expend your energy. IMHO just clean it and paint it.
check out this "wood " bed ! mark914 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 10-05-2010 05:16 PM
Who has the worst rust? bassdude 1973 - 1979 F-100 & Larger F-Series Trucks 25 04-01-2010 03:53 PM
just testing mitch150 User Gallery & Picture Display 0 09-28-2008 07:20 AM
Ford Truck Check fastmover N. California Chapter 23 05-20-2008 05:38 AM
Paint code SS '55 special order? mark914 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-23-2007 10:18 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
