56 Ford F-series water pumps and donar pulleys. - Ford Truck Enthusiasts Forums
Old 05-25-2014, 10:24 AM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
I have a 56 ford f-100 and 250 with 272 and 292 Y blocks. They both have double 3/8" pulley dampners (C3TE-6316-D, 63/64 truck with two 3/8" belt generator option). Im looking for a double water pump pulley that will bolt on and line up with these dampners. Hopefully it will have the same bolt pattern and shaft hole (3/4").
Is there a pulley or pulleys with a part number I can search for that will be a good match? Im looking for something in the 6 1/4" diameter range to clear the aftermarket generator to alternator conversion sold by John Mummert. It has a 3/4" shaft hole and is 2 3/4" high. The pulley I have now has no number on it to identify it.
I have heard some of the double pulleys on the FE engines are a good swap for this project, but you may have to drill the shaft hole (enlarge) to 3/4".
Old 05-25-2014, 01:48 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I looked though my pile of Y block parts.....no double pulley but several singles. I'm wondering if only the HD truck Y's used the double pulley.
FE pulleys are pretty big, maybe a SBF will work?
Old 05-25-2014, 02:17 PM
What is a SBF pullley, lol?
Old 05-25-2014, 06:41 PM
tinman52's Avatar
Welder User
Quote:
Small Block Ford 289-302
Old 05-25-2014, 08:34 PM
Im still going to keep checking all my options and this time Im taking a straight edge. If I lay it across the back of the pulley and it measures 2 9/16" to the inside of the hub, its going to be close. Obviosly needs to be set up for 38 pulleys and has to be real close to 5/8" center to center at the bottom of the groove. I will let every one know what I find.
Tech: Budget 302/351 Serpentine Drive 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-30-2014 10:02 PM
Harmonic Balancer Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-30-2014 12:09 PM
Double Pulley Water Pump Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-23-2014 11:51 AM
Double Water Pump Pully Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-23-2014 10:18 AM
power steering bracket raven3 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-01-2014 09:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
