cowl vent removal - Ford Truck Enthusiasts Forums
cowl vent removal
Old 05-24-2014, 09:38 PM
abe's Avatar
abe abe is online now
abe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud ofabe has much to be proud of
cowl vent removal
I am getting parts off of a 52 F2. The cowl vent is complete and appears to be in good shape.
I am more familiar working with 53-56 trucks. So i am not sure how to remove the cowl vent. I removed the 4 screws from the front of the vent on the outside. I can see 4 other screws on the back side when I look up at it under the dash. How do I get them out?
Also is the handle attached to anything under the dash? And does the whole unit lift out through the vent hole from the outside?
Thanks. These cowl vents are a lot different than the vent on my 54.
Old 05-24-2014, 10:37 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is online now
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
Here's Bob's old thread that explains it real well. Stu
http://www.ford-trucks.com/forums/87...t-removal.html
Old 05-24-2014, 10:49 PM
abe's Avatar
Thanks, that helps a lot... but still have this question: how do I get the four screws out of the back of the vent? from the top like I did for the front of it?
Old 05-24-2014, 11:26 PM
Yes, there are captive nuts along the back lip same as front. Stu
Old 05-25-2014, 12:03 AM
abe's Avatar
Are they accessible from the top?
Old 05-25-2014, 02:04 AM
Yes. Here's mine. Stu
Old 05-25-2014, 07:41 AM
abe's Avatar
Thanks, Stu. I couldn't see them. They must have been under the weather stripping. I was running out of time so I will get it when I go back.
Old 05-25-2014, 12:05 PM
aussiecowboy aussiecowboy is offline
aussiecowboy is gaining momentum as a positive member of FTE.aussiecowboy is gaining momentum as a positive member of FTE.
They are a pain in the butt to remove but even worse when you're installing it back into a freshly painted cab.
Old 06-09-2014, 11:38 PM
abe's Avatar
Quote:
Last Saturday, I tried again to get the cowl vent off. I could not access the 4 screws at the back of the vent. Excuse me for being so thick but how do I get to them if the vent door covers them when closed and pretty much covers them when open?
Thanks, Again!
Old 06-10-2014, 12:14 AM
The lid comes off. Four screws. Stu
Old 06-10-2014, 12:20 AM
abe's Avatar
Oh, now I get it! Amazing how different the cowlvdnts are from 1952 to 1953.
Thanks!
Old 06-10-2014, 12:53 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Abe, Here's a tip for you. The screws in the lid don't have to come out all the way. Just loosen them a bit and you can slide the screw heads out through the larger part of the screw holes in the hinge. I knew this but still forgot once and in the process broke off a head or two, when I didn't have to.
Quick Question On Cowl Replacement Stoned06 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 12-09-2015 08:56 PM
84 Ford F250 Cowling removal FilmCarp Paint & Bodywork 5 08-16-2014 11:05 PM
cowl vent tomrflorida 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 08-03-2014 05:03 PM
1956 cowl vent hwyhogg 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-03-2014 06:43 PM
1951 F1 Cowl Vent Seal 1951flatheaddave 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-10-2012 10:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
