72 F-100 302 heads or engine - Ford Truck Enthusiasts Forums
Old 05-24-2014, 03:23 PM
Quentin10 Quentin10 is offline
Quentin10 is starting off with a positive reputation.
Im looking for a place where I can buy used iron heads for my truck or a used 302 engine need help
Old 05-24-2014, 04:58 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Quentin10, Welcome to and the Bumpside Forum.
Hey look if it aint no real BIG Secrete why don't you tell us where in the big ol world you are hiding in and maybe someone close by can help you.
John
Old 05-24-2014, 05:02 PM
I live in Wichita Kansas
Old 05-25-2014, 09:43 AM
yetiman38237's Avatar
yetiman38237 yetiman38237 is offline
yetiman38237 is gaining momentum as a positive member of FTE.
If you are looking for stock you can purchase a complete rebuilt set from parts store like Advance for about $200 ea. They have 20% off right now so that will help some. I would think the scrap yards are full of 302 cores and engines......just have to get out and make a few trips or calls?
Old 05-25-2014, 07:08 PM
bmuhlbach's Avatar
bmuhlbach bmuhlbach is online now
bmuhlbach is gaining momentum as a positive member of FTE.bmuhlbach is gaining momentum as a positive member of FTE.
You can use heads up to like 1995 after that I think they change the exhaust ports so your manifolds may not bolt up. So finding a set of heads should be pretty easy from a 5.0 H.O.
Old 05-27-2014, 03:04 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
I would stick with mid 80's to early 90's heads. Mid to late 70's 302's and 351W's were lower compression and some had wierd hook-ups for the smog pumps. As far as I recall, 1976 being the worst.
351 engine parts on a 302? easyridin 1987 - 1996 F150 & Larger F-Series Trucks 3 08-23-2015 08:07 PM
1976 Ford F150 Truck 302 Engine - need cylinder heads E1234 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-12-2015 01:04 AM
converting efi 302 to carburator F100trauma 1973 - 1979 F-100 & Larger F-Series Trucks 20 02-28-2015 12:20 PM
302 parts in 351w steve33444 1987 - 1996 F150 & Larger F-Series Trucks 19 12-12-2014 08:33 PM
302 vs. 289 heads dogstar Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 21 11-11-2010 12:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
