Looks to me like you have big block springs, and a small block engine........
Seriously though, the springs may just be too long/stiff for the application. If they are new, they may need a bit of time to "settle", but that looks like a lot more than can be attributed to "settling" of the springs.
I would agree .. Are the springs original to the truck ? and what does the Vin say was the original motor for the truck?
The vin says 302 I installed a 347 stroker with aluminum heads. The springs are the springs came with the truck.
So the springs are what they are .. You might go with some variable rate springs, if those springs are original .. It will ride a lot better .. and then cut to fit when your all done putting it together
I have another 1978 f100 I don't want to but maybe ill pull the springs of it and compare them. You guys think it makes a difference that the one im building is a 1978 1/2. is it possible the springs in there now are for a f150 that's heavier suspension right?
I'm comparing the difference in stock spring height in 2 motors only
Yes, there is a difference. I put big block springs under a small block powered truck once. The result looked much like the pics posted by the OP.
Small block, around 450-500 lbs. Big block, 600+
So before doing all that work I loosend every bolt underneath drove the crap out of it on my gravel driveway and now it looks like the pic I have not tightend anything but I may be good now. Seems like it was stress on it after all.
