DJM beam kit camber seems out - Page 2 - Ford Truck Enthusiasts Forums
Old 05-25-2014, 02:31 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
You don't happen to have lift springs do ya?
Josh
Old 05-25-2014, 02:51 PM
CDN Sharky's Avatar
CDN Sharky CDN Sharky is offline
CDN Sharky is starting off with a positive reputation.
Ok here is a pic of me and the boy on it id say easy 380/400 lb. what do you guys think. Leave it be until she is all together?
Old 05-25-2014, 03:00 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Looks to me like you have big block springs, and a small block engine........
Seriously though, the springs may just be too long/stiff for the application. If they are new, they may need a bit of time to "settle", but that looks like a lot more than can be attributed to "settling" of the springs.
Old 05-25-2014, 03:08 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
I would agree .. Are the springs original to the truck ? and what does the Vin say was the original motor for the truck?
Old 05-25-2014, 03:28 PM
Bullitt390's Avatar
Big block and small block springs do not make that much of a difference. Even moreso once the guys put their weight on it as in the demonstration.
Josh
Old 05-25-2014, 03:29 PM
CDN Sharky's Avatar
The vin says 302 I installed a 347 stroker with aluminum heads. The springs are the springs came with the truck.
Old 05-25-2014, 03:34 PM
redroad's Avatar
Quote:
Josh
On my F350 dually it was 1" in height
Old 05-25-2014, 03:38 PM
redroad's Avatar
Quote:
So the springs are what they are .. You might go with some variable rate springs, if those springs are original .. It will ride a lot better .. and then cut to fit when your all done putting it together
Old 05-25-2014, 03:40 PM
CDN Sharky's Avatar
I have another 1978 f100 I don't want to but maybe ill pull the springs of it and compare them. You guys think it makes a difference that the one im building is a 1978 1/2. is it possible the springs in there now are for a f150 that's heavier suspension right?
Bullitt390's Avatar
Quote:
Comparing an F350 dually to an F100?
Josh
Old 05-25-2014, 03:46 PM
CDN Sharky's Avatar
Ok there is 1 inch difference just measuring my parts truck is shorter it has in inline 6 in it. that could be it may have to switch them into it.
Old 05-25-2014, 03:53 PM
redroad's Avatar
Josh
I'm comparing the difference in stock spring height in 2 motors only
  #28
Old 05-25-2014, 03:55 PM
That 1" difference will make a huge difference in camber. I bet it will sit much better on the shorter springs.
  #29
Old 05-25-2014, 03:59 PM
Yes, there is a difference. I put big block springs under a small block powered truck once. The result looked much like the pics posted by the OP.
Small block, around 450-500 lbs. Big block, 600+
  #30
Old 05-25-2014, 04:14 PM
CDN Sharky's Avatar
So before doing all that work I loosend every bolt underneath drove the crap out of it on my gravel driveway and now it looks like the pic I have not tightend anything but I may be good now. Seems like it was stress on it after all.
Projector headlight retrofit 86F150302 1987 - 1996 F150 & Larger F-Series Trucks 26 12-30-2016 09:25 PM
1979 F250 Rust Woes rlacan71 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-19-2015 04:07 PM
1979 F-250 rlacan71 1973 - 1979 F-100 & Larger F-Series Trucks 24 08-16-2015 04:30 PM
pictures of the 01 expedition fuel pump replacement via cutting through the floor Danny01Expo 1997-2006 Expedition & Navigator 11 06-11-2014 12:29 AM
WhiteOut's 01's V10 Build! WhiteOut FX4 1999 to 2016 Super Duty 0 04-02-2014 09:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
