2005 f150 transmission problem - Ford Truck Enthusiasts Forums
Old 05-24-2014, 12:14 PM
challahan challahan is offline
challahan is starting off with a positive reputation.
I have had the check engine light on for a while now with the truck shuttering and bucking along with loss of power. feels like there is something holding back the power. Just a couple days ago I was driving on the freeway and all of a sudden it felt like I was in neutral, tried to accelerate but the engine revved but wouldn't go anywhere, I clicked the overdrive on and it went into gear and I was able to drive home. Now every time I drive it, it goes a block or two in drive then again feels like neutral, put in overdrive and it goes into gear. Please help!!!! I just put in new ignition coils.
Old 05-24-2014, 03:11 PM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
Have you had the codes checked yet?
Old 05-25-2014, 10:17 AM
Ya the codes read multiple misfires.
Old 05-25-2014, 11:39 AM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
The snap ring for the OD servo prob broke. The piece gets in the valvebody and hangs up the shift valve. The misfires are prob worn plugs and need to be fixed ASAP or you will be replacing cat converters too.
Old 06-02-2014, 01:31 PM
checking into it
Thanks 70f100longbed. Im going to take to a transmission repair place and tell them what you said. Do you have any idea how much it is to fix this?
Thanks again
Old 06-02-2014, 02:59 PM
stuart1 stuart1 is offline
stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.stuart1 has a very good reputation on FTE.
Don't go into a place with what may be incorrect advice.
Let them figure it out.
If it comes back as what you are told ok.
It may be something altogether different.
It may only need a widget worth $1.49. But if you are prepared for XXXX times that and tell them what your neighbours uncle three times removed said they may say, "hmmmmm".
Old 06-02-2014, 03:56 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
Thanks again
I had the servo ring snap on my 04 5.4 and I told the transmission place I suspected that was the problem (from information on this board) but they pulled it out and took it all apart and said "well yes , it DOES need the ring but there is other wear also , so I got it rebuilt for $2500 , if I had it to do over , I would have had them just drop the pan and see if the snap ring was broken and replace it , there is a great video on here that shows what a simple job it is . In the future I would just replace it myself .
Old 06-02-2014, 04:50 PM
Thanks again
The problem with taking it to a trans shop for the snap ring is now since they have been into the trans if anything else fails its their fault and the customer will want it fixed for free. That's why most shops will try to sell you a complete overhaul or reman trans. I have seen it many times. It's not hard to pull the valve body and fix it yourself. You might get lucky and find a shop that will replace just the ring.
Old 06-02-2014, 07:30 PM
Quote:
yes , this is true , if I had it to do over again , I would have changed it out just like in the video , if it only went another 30,000 so what ?
Old 06-02-2014, 07:33 PM
After they R&R'd the trans , I had a clunk , I searched in here and told them they didn't grease the driveshaft enough , OH NO !!!! what does the INTERNET know ,....they pulled the cover off the pumpkin, showed me , they said the ring & pinion was shot , I said bull**** !! put it back together charged me $90 but they had taken the driveshaft out to inspect the u joints and re greased it it was SILENT !!!! who knew !!!
05 F150 5.4 (lost drive & overdrive) rweidner 2004 - 2008 F150 7 08-02-2016 09:11 PM
Truck not going into overdrive hack 96' F150 lievense81 1987 - 1996 F150 & Larger F-Series Trucks 1 08-26-2015 07:38 PM
AOD seems to stay locked up nastruk95 Clutch, Transmission, Differential, Axle & Transfer Case 1 07-30-2015 12:25 PM
1992 Ford F150 Transmission E40D Issues Kmac1992Ford 1987 - 1996 F150 & Larger F-Series Trucks 15 09-03-2014 10:19 AM
Need help! Transmission Problems BigZ97 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 03-07-2014 12:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
