aaaarrrrggggghhhhh
IF that's true AND add in the MM ECM loves Motor Craft plugs it almost becomes mandatory to use them in our motors. Even if it's not 100% true as I recall that blurb the fact the ECM is most happy with them only adds to the reasons why they're a good idea.
I posted this a short while ago for another newbie to plug changes in these engines:
-Used nothing but Motor Craft plugs! While Autolite makes a perfectly acceptable alternative MC are close by, cheap enough to buy locally.
-NEVER let them run longer than 50-60K miles--EVER! Regardless the BS spread how they're good for 100K miles as consumable items they have a finite life.
-Use nickel-based anti-seize on plug threads---there is no down side.
-Torque with a known good wrench set to 21-23 ft/lbs. At first click or indication torque is reached STOP! FWIW advice about the torque wrench itself: range is important. I use a 5-75 ft/lbs Wright Tool so at 21-23 ft/lbs it will work well given the standard tolerances of the click type torque wrenches.
The issue of spitting or blown plugs seems to originate more from improper installation rather than any huge defect in the head or its design. Yes it seems as though the puny 3 threads per hole contacting the plug body is the real problem and while its highly inconvenient when it happens to one of us its just not that common when measured against the number of Modular Motors in use.
It happens, it sucks (or "blows" in this case ) but with a bit of caution and care you're not likely to be the root cause of subsequent incidents, if they ever occur.
HTH
PS: This thread tends to shred a lot of thoughts about torque and anti-seize---enjoy: https://www.ford-trucks.com/forums/10...ead-heads.html
HTH
While I can't (yet) re-find a blurb I once read about Motor Craft plugs having a slightly different thread profile than most any other plug brand, one that obviously will more exactly fit the Modular Motor heads.
The factory spec is 12-14 ft-lbs with clean, dry threads. I would clean as much of the anti-seize off as you can and retorque them all to 14. I don't think you're doomed to them all spitting out, but definitely time to take some corrective action!
The "ONLY use Motorcraft plugs" myth seems to never die. I put Bosch plugs in my V10 a couple of years ago, and my 4.6L engine is currently running Autolites. Both ran fantastic. Neither the PCM nor the coils give a hoot which brand of plug is installed in the head. The two of them are responsible for delivering a high voltage pulse to the plug at the right time; the PCM has no clue what happens after that.
I've referenced this post before, I think its appropriate most any time Modular Motor plugs are discussed https://www.ford-trucks.com/forums/1...ead-heads.html IMHO there's a ton of great if anecdotal info there about this very issue.
Like Tom I'd suggest at least loosening the existing plugs and using a torque wrench this time. Its too bad you don't have a dial type torque wrench to see how tight they are now. Anti-seize, well I leave that to you........
phillips91
05-24-2014 06:59 AM
