egr ports
egr ports
Hey 6T8stang.
Happy 4th to ya. I just had one of these problems, it seems to be happening on the higher mileage engines now. I would remove the throttle body first and do a good cleaning of it while i am at it. Try not to let cleaner run into the tps switch while cleaning. Next i would remove the part that bolts to the intake and and throttle body, and clean the egr ports real good, make sure you get all the stuff out of them. I would also clean the AIC area on the thottle body as well after removing the air inlet controler, or the idle control solenoid. Make sure the TPS is pluged in correctly when done Good luck let us know how it goes.
umdstang
05-05-2004 04:32 PM
