A/C clutch/bearing
05-23-2014, 01:41 PM
on
A/C clutch/bearing
1987 F150 5Lt., A/C, PS
Need to replace the A/C clutch/bearing, looking for any help/advice to replace it?
05-23-2014, 02:42 PM
Pretty easy actually. Remove belt, remove nut in the center of the outer clutch plate, outer clutch plate will come off. You may need to pry it a little. After that, remove snap ring, and pulley/clutch comes off.
05-23-2014, 11:57 PM
Not a hard job. You will need a press to remove/install the bearing in the pulley. I found the bearing on ebay
05-25-2014, 12:18 PM
on
Any idea what the air gap should be?
05-25-2014, 03:49 PM
Quote:
Originally Posted by
epdukes13
.021-.036 inches. It's set by shims.
05-25-2014, 08:47 PM
on
F150xlt
Thx, I left it at .031
annaleigh
12-21-2015 11:41 PM
Kart18
10-27-2011 12:44 PM
F250saleen
12-26-2009 04:54 PM
runcrashboy
17
02-02-2004 01:06 PM
AFD301
06-14-2002 07:55 AM
