Double Pulley Water Pump - Ford Truck Enthusiasts Forums
Old 05-23-2014, 11:51 AM
Outlaw56 Outlaw56 is offline
Outlaw56 is starting off with a positive reputation.
Im working on a Y block with has a double pulley dampner (3/8"" both grooves) The groves are 1 5/16" center to center. I would like to replace the stock water pump pulley (single belt) with a double pulley. It would have to be 6 1/4 in diameter, 3/8" belts. I also need a replacement pulley for the alterenator. When I am done, my goal is to run two belts which both connect dampner, water pump, and alternator.
Does anyone have a suggestion on what donar water pump might work off another vehicle?
I think the add on part for the alternator will be the easy part.
3/8" vs 5/8" pulley on 1950 Canadian Mercury Flathead Poes 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 06-06-2015 02:55 PM
Tech: Budget 302/351 Serpentine Drive 51dueller 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-30-2014 10:02 PM
Harmonic Balancer Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-30-2014 12:09 PM
56 Ford F-series water pumps and donar pulleys. Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 05-25-2014 08:34 PM
Double Water Pump Pully Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-23-2014 10:18 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
