Double Water Pump Pully - Ford Truck Enthusiasts Forums
Old 05-23-2014, 10:18 AM
Outlaw56 Outlaw56 is online now
Outlaw56 is starting off with a positive reputation.
Im on the hunt for a double water pump pully to replace the single pully I have now. I want to set up double belts. I have a single belt that runs on 3/8" pullys. My balancer has been swapped out so its already a double pully. I just need to change pullys on the water pump and alternator. When Im done, I will have two belts running off the dampner, water pump and alternator.
On another post, it looks like a double pully off a late 60's big block worked for this project (Ford #C6AE-8509-E).
I also need a double pully swap on the alternator, but I assume thats an easy after market option (also 3/8" pullys).
Power steering pump pully snowcat1964 1973 - 1979 F-100 & Larger F-Series Trucks 23 07-20-2014 01:23 PM
Harmonic Balancer Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 05-30-2014 12:09 PM
Double Pulley Water Pump Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-23-2014 11:51 AM
Water pump question cyris426 1973 - 1979 F-100 & Larger F-Series Trucks 4 03-31-2014 09:09 AM
66 F100, got a double pully? johncardi 1961 - 1966 F-100 & Larger F-Series Trucks 11 05-06-2011 08:23 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
