strange A/C noise
strange A/C noise
I used the a/c for the first time this year on my 2013 F250 and heard some noises I don't remember hearing before. When the a/c(or defrost) is on every 12 sec or so I hear a hissing sound that lasts for a couple of seconds then goes away. Is this the compressor cycling and if so is it normal to hear it inside the cab?
I know it has to do with the a/c because if I shut it off as the hissing sound is being made the sound will instantly stop. Other than the noise the a/c works fine and blows cold air.
Also, if it matters I have the standard control panel, not climate control.
Crystal
Fordman19762003, I have that same hissing noise in my truck too, seems to do it anytime the a/c or defrost is on, and also about every 10 or 12 seconds.
I mentioned this to the dealer twice and they tell me it is just cycling and its normal, for some strange reason I'm finding that a little hard to believe.
SD Dually
SD Dually
SD Dually
SD Dually
