abs light on
Then it might be the sensor. Too bad you don't have access to the
right diagnostic tools to pin point this.
Do you have an extra sensor that you can swap in to test with?
I wanted to verify what you have replaced.
The rear sensor
The right sensor
The left sensor
Is this list correct?
Sean
The rear sensor
The right sensor
The left sensor
Sean
yes that list is correct also have tried different new sensors on the left front also have put two hubs on the right front and getting ready to take that hub off again because i noticed there is play from top to bottom and my ball joints are all new so its not them . when i put my wheel back on after cleaning the tone rings so gonna take this one back and have them credit since its under warranty and go out to ford and get one of there hubs and put that one. we are getting a reading from the sensors but there reading fast and were thinking thats what is setting the light since the reading from each front sensor is different thats why we were leaning towards the abs module thninking module is screwing the info up
Also do a good inspection of the plugs for any corrosion
that WILL cause errors. Clean with contact cleaner then
apply dielectric grease to keep it form coming back.
This could be just a weak sensor on one side. The true
tell all would be to look at the signal on a scope to
see shat the signal looks like.
If you have a scope and you spin the wheel you should
see something that looks like this. BTW this is the Fan
Speed Sensor on the 6.0L diesel
If I have time tomorrow I pull one form the wheel speed sensor
and I will post it for you and anyone else that wants to see.
Sean
Sean
i have put new front sensors on both y2 that is why i did not specify right or left
thanks hot rod will lool in to that i have put new hub on the RIGHT side 4 different times now thinking i was getting bad ones. Never changed the LEFT front because it never had noise in it and spun freely but will look into it
#29
#30
The following users liked this post:
