Turns out my Dana 53 is a 2.89 Lincoln
Greetings, update after all the help I received about my Dana 53, and my thoughts about building a 9" to keep as a back up, I figured I'd let you know what I found today when I pulled the cover off the D 53. Well its a 2.89 track lock with 21 spline c clip axels. According to my research this means its out of a Lincoln, as the 2.89 was only made for the Lincoln, and used Ford axels . Using the formulas on the internet, with a non overdrive automatic ( I have a C-4), and my 295/15 tires I should turn about 2549 RPM at 65 MPH. That ratio, along with not finding any noticeable wear or damage on any of the gears, reinforces my decision to leave it alone and keep an eye out for a good 9" with a similar ratio for a back up project. The limited slip still works well and every thing else is avail thru Kaiser ****** Auto Supply, with the exception of axels. The date on the ring gear is 7 13 64, so I'm guessing it was probably out of a 65 Lincoln. I know Pics- (There is rag lint and oil distorting the sharpness)
vettman
11-11-2011 07:12 PM
rowekmr
05-28-2010 12:08 PM
Mike12pt
06-29-2004 11:56 PM
Bern_F150_4x4
08-25-2003 10:09 AM
