2005 starting problem - Ford Truck Enthusiasts Forums
Old 05-21-2014, 10:50 PM
mrwrench mrwrench is offline
mrwrench is starting off with a positive reputation.
the engine start for a second and stop , start /stop start / stop ............
check with scangauge and all the values seem to be ok .
I connected the scangauge in my other truck and the values are pretty same .
Tried a new cam sensor and nothing .
please help thanks so much
Old 05-21-2014, 10:52 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
Say again?
Josh
Old 05-21-2014, 11:14 PM
Mr.Nobody's Avatar
Mr.Nobody Mr.Nobody is offline
Mr.Nobody is a splendid one to beholdMr.Nobody is a splendid one to beholdMr.Nobody is a splendid one to beholdMr.Nobody is a splendid one to beholdMr.Nobody is a splendid one to beholdMr.Nobody is a splendid one to beholdMr.Nobody is a splendid one to behold
Truck starts and dies on it's own? How long does it run? I think help would be more forthcoming with a better description and an idea of what PIDs you are checking and what their values are.
Old 05-22-2014, 10:31 AM
Quote:
ficm 49v
icp 500 plus
ficm 11v
ipr 15
those values are similar tham my other truvk that run ok.
i started today after many tries , and it wont idle, I have to keep my foot on the acc pedal ,
Old 05-22-2014, 10:41 AM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Quote:
Originally Posted by mrwrench View Post
ficm 49v
icp 500 plus
ficm 11v
ipr 15
What are the ICPV's at KOEO?
Old 05-22-2014, 11:11 AM
icp more than 500
Old 05-22-2014, 11:18 AM
MarzRickey MarzRickey is offline
MarzRickey is starting off with a positive reputation.
ficm 49v
icp 500 plus
ficm 11v
ipr 15
Check fuel pressure ?
if it starts but wont stay running and all vitals you mentioned were ok that is what i would check next.
Old 05-22-2014, 11:40 AM
CPB1's Avatar
CPB1 CPB1 is offline
CPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to beholdCPB1 is a splendid one to behold
icp more than 500
Check ICPV's (ICPV's = ICP Volts) at KOEO (KOEO = Key On Engine Off)
This checks your ICP sensor
Old 05-22-2014, 11:52 AM
Bullitt390's Avatar
KOEO:
ICP psi
ICP volts
IPR
Map
Baro
EBP
FICM main
Josh
Old 05-26-2014, 09:39 PM
it start with carbuartor cleaner , and no idle .
Old 06-02-2014, 07:12 PM
does the oil filter must be full?
I just remove the oil filter and it was empty , I dont know if that is normal .
Old 06-02-2014, 10:15 PM
Mr.Nobody's Avatar
When you open up the oil filter, there is a drain that let's the oil run back to the oil pan.
scangauge simbrn 6.0L Power Stroke Diesel 12 10-25-2015 11:34 AM
322 miles Dascro58 6.7L Power Stroke Diesel 1 07-01-2015 09:31 AM
ScanGauge II ERG Readings Bkiggins 6.0L Power Stroke Diesel 2 03-19-2015 07:34 PM
Scangauge Codes satwood 6.0L Power Stroke Diesel 15 11-29-2014 08:58 AM
VGT % rattleNsmoke 6.0L Power Stroke Diesel 7 05-11-2013 01:21 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
