Truck Stance/Height
Truck Stance/Height
Hi All,
Does anyone know how to achieve the stance of the truck in the link below? Do you all think this looks better on a short bed or a long bed truck? Can I jus cut coil springs and be done with it or will it be more involved? Thanks!
Link:
1301Cct 01 O 1976 Ford F 100 Stock Front End Photo 1
Link:
Front lowering shocks aren't required... all drop beams do is increase distance of the spindle relative to the I-beams' center line so it's the same suspension travel as stock - about 2.5 inches from the I-beam to the bumpstop.
Ya *might* get away cutting up to half a coil. MIGHT. Beyond that and camber gets whacky and of course, it'll end up with less suspension travel.
Dream beams are an option but you run into suspension travel problems. Crown vic and mustang 2 front suspensions are pretty common swaps and handle very well. In the back it looks to have a moderate drop, maybe just a spring under axle. The rear tires also look to be larger than the front.
From everything I have read, cutting coils is not the best route. It can cause lots of problems and WILL decrease drivability. I remember riding in a lowered truck when I was younger, much younger, that was done the cheap way and it felt like there was no suspension. Every little bump went through your spine and rattled your teeth. Even seams in the highway rattled your dome. I would save the money and do it the "right" way.
Just my 2 cents.
Just my 2 cents.
Mitch1129
03-27-2015 08:26 PM
