1356 Tcase chain
The guys said it, you already are there, no need to save a few bucks, cheaping out might become expensive later down the road, and Fordman, your logic is right, the chain is plenty strong already and usually the T-case sees little use, no need to spend extra time and resources on that gear mod.
There is a pump modification you should consider while you're in there Mike, it's a pump retainer mod to prevent the pump from spinning: Rebuild your own transfer case. BW1356 - FSB Forums
Around picture 21 in that write-up
wezol5484
05-06-2010 12:23 PM
alabamabuddog
08-25-2003 10:58 PM
