Ring and Pinion
No need to be scared of it. I used USA standard gears on my truck this spring. First time I've ever used them, and it will probably be the last. I haven't had any problems with the set since the install, but they were a bear to get in there. The ring fit very tight on the carrier. I have always put the pinion in the freezer overnight and been able to drop the inner bearing on with no press, not with the USA Standards. Never had an issue with the Richmond gears I've used in the past.
dmeyer 351 4x4 rebel
28
12-26-2010 08:37 AM
rdw516
01-10-2010 09:30 PM
psychomech
1999 to 2016 Super Duty
03-18-2008 10:51 AM
therigwelder
05-27-2005 07:24 AM
