While I was rebuilding the limited slip clutches in my carrier, it rolled off my workbench and onto the concrete floor.
It's a little bent but not bad. None of the teeth are broken. I'm thinking it will be OK, all it has to do is pass through a magnetic field and produce a signal.
Tone ring will still function as intended. The problem I would have with it would be a possible vibration in the rear end. Not saying it will, but is it really worth the chance, since it is still apart?
I second the judicious application of a hammer. I'd probably also take a file to any burrs from the drop or hammering without getting too crazy about removing metal. Make sure you clean said filings off well--don't want those floating around in your pumpkin.
That is why you should never start by changing the VSS when you have a VSS problem. It is hard to get the numbers back and it just makes things worse.
Besides the VSS is very seldom the problem anyway.
