Power Steering Conversion - Ford Truck Enthusiasts Forums
Old 05-21-2014, 12:42 PM
wild78's Avatar
wild78 wild78 is offline
wild78 is starting off with a positive reputation.
I have a 1960 F100 with a 292 4 speed. I'm looking at doing the Toyota steering gear with the saginaw pump conversion. Is there anyone out there that has done this conversion that I can speak on the phone. Before I order parts I'd like see what I should and shouldn't buy.
Thanks,
Bill
Old 05-21-2014, 02:11 PM
mgargiullo's Avatar
mgargiullo mgargiullo is offline
mgargiullo is starting off with a positive reputation.
Let me start by saying I haven't completed this swap, but I started down the path. I'm in NJ and early 80's Toyota 4x4s were driven into the ground around here. I called a few yards and they all said they'd have to find one if I wanted to pay for it up front.
The hard part is the pitman arm. I was going to purchase one as I'm not a certified welder and you and your passengers life depend on this piece. CPP carries a toyota to ford arm for around $60. In fact I spoke with them about the swap and they were very helpful. After a few days I went back to their site and just a little further down the page, I saw they sell a whole kit. It's not cheap at just over $500, but it's everything but the power steering pump. They have that too if you need it. At that price I'm likely to just purchase the kit and know it's a good steering box with the correct hardware.
Either way... they have the pieces you need. Classic Ford Truck Parts-1948-1964 Parts. The Finest in Suspension, Brakes, Steering and Accessories.
Mike
Old 05-21-2014, 02:32 PM
wild78's Avatar
I've found several sites that have the parts - however - a few lingering questions.
Saw one site that said the saginaw pump won't work with the standard exhaust. I assume they are talking about the cross over pipe at the front of the engine.
So if I change the exhaust say to a set of Patriot headers - will the toyota power steering gear fit.
Anyone have a conversion completed that can give me some input?
Old 05-21-2014, 05:53 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
I did the cpp box on a 1960 with a 223. I don't recommend the Toyota box.
Old 05-21-2014, 06:51 PM
wild78's Avatar
damifiknow - just read your other post about the Toyota box. I have a 292 in mine. Any chance you can post a picture of the steering box so I can see how it sits with the clutch linkage. I don't want to order anything until I have a pretty good idea what is going to work.
Thx,
Bill
Old 05-21-2014, 07:58 PM
Damifiknow's Avatar
Quote:
Thx,
Bill
Hydraulic Clutch
Ford Minivan Pump I think 86?
Old 05-21-2014, 08:56 PM
wild78's Avatar
Thank you very much for the pics. I'll have to call CPP and talk with them.
Old 05-22-2014, 06:22 AM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
Toyota box is in my truck which has a 292. Has been since about 2008.
Old 05-22-2014, 06:09 PM
Damifiknow's Avatar
Quote:
I couldn't get Toyota box to line up with stock column. Maybe I had wrong bracket but the hook up for column came out right under the brake pedal.
Old 05-23-2014, 12:58 PM
Walston's Avatar
toyota power steering conversion kits Madathlon 1948 - 1956 F1, F100 & Larger F-Series Trucks 89 10-27-2015 04:06 PM
Power steering conversion rio68 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-21-2015 01:39 AM
Power steering conversion Caveman2851 1957 - 1960 F100 & Larger F-Series Trucks 11 08-14-2015 09:38 AM
power steering help needed!! free72 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-14-2014 11:34 AM
1964 Power Steering Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 9 08-13-2014 11:25 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
