Door Panel Switch Repair Question
What is the best way to repair the door panels where the electric window switches attach? Many trucks I have looked at have been switch broken so I assume it is a common repair. I searched this forum and did not find any related posts.
Building up the area where the screw attaches is a given but what is the best material that will stick and not melt the panel. The panels are in relatively good shape so I do not want to replace them.
I am hoping some one knows of a repair kit. I have seen many doors with the same problem.
He's talking about where the switch plate screws into the door panel. That spot on the panel cracks and the screw has nothing to go into do it just floats there.
#1 I will take an L bracket and either use gorilla glue on the inside to glue it to the door panel and use a U clip nut to slide over the other end of the L bracket then screw through it, or
#2 I will not glue it, I will use 2 U clips and run a screw into the U clip through the side of the panel and then attach with the other U clip as normal.
Hopefully you can visualize what I'm talking about.
You may be able to plastic weld it, if you can hold it in place and go completely over the metal bracket, or if you go slow enough you may be able to build up the weld enough to drill a new hole. I'd use a welder though, not a soldering iron. Here's some cheap ones that may work.
Plastic Welding Equipment and Plastic Welders at Harbor Freight
I still think the gorilla glue or even a 2 part epoxy would be just as good though.
MR KROGOTH
05-03-2019 06:54 PM
FordTruckfan89
10-01-2015 12:30 PM
