95 f150, 4.9L died on the way to work
This might help you decide what you want to do.
A Buildup of Ford's Classic Inline Six | Horsepower | PowerBlockTV - Full Episodes
The fiber type timing gear last around 175k miles.
The other problem with the 4.9 is around 200k and higher miles you start to get blow by.
If you look at the small air filter in the air filter box that's the fresh air intake for the PCV system. If and see oil residue it's time for a rebuild.
You could do a compression and leak down test and if everything checks good just replace the timing gears.
If you rebuild the engine figure around $600 for machine shop work such as hot tank, boring the block, grinding the crank recondition the rods, pressing new pistons onto the rods, balancing the rotating assembly, install new cam bearings, resurfacing the head and a valve job. You may also need to replace some valve guides in the head. Then add on the new parts for around $600.00. New pistons, camshaft, rod and main bearings, gasket set, oil pump and screen, oil, antifreeze, paint for the engine, reconditioned or new fuel injectors, etc...
If money and time is no problem go for it.
Hey f150xlt,
Good info. Question just to clarify
Are you saying the factory parts last approx 175K?
Reason I ask is I am running a new to me 95 300 six 5 speed and it has 172k miles now. All sounds good and running fine since I fixed the fuel pump ground problem that stopped the previous owner from driving it.
Thanks, Joe W
Hey f150xlt,
That was my experience with my 88 that I purchased new.
Here's a thread about a knocking sound at 198K but the gears didn't completely fail until 275K. I'd say he got his money's worth.
4.9L died on the interstate today. Help! - Ford F150 Forum
What's interesting is Ford used a fiber timing gear on the Model A that also made a knocking sound when it was close to failing. LOL.
I wish I could post my mileage. The truck itself has 196k miles, but the engine is on from a junkyard. It could have 40k or 200k. I simply don't know.
I still haven't decided if I'll rebuild. I think I'll put the truck in my bay today and start trying to get at the gears.
Any tips for how to get the old fiber gear off without turning the cam? I'd like to make it as easy as possible and also try to avoid having to re-time the engine
Below is a picture of the tools the factory techs use. My guess is the gear will crumble so break the rest of it off and grind and split the metal collar off. Just make sure no metal particles end up in the engine.
Using your hands rotate the camshaft gear to get the alignment dot in the proper position. To move the crankshaft gear, use a wrench on the crankshaft damper bolt to move the crank gear to the proper position. (Dot to Dot) as shown in one of the pictures below.
Taking the spark pugs out will make it easier to turn the engine over. As long as you don't pull the distributor, the timing should not change.
The nose of the camshaft is tapped for a bolt. To install the new camshaft gear you can can use a 7/16 inch NC 14 threaded bolt and use a stack of washers or shims to press the gear back on. The gear is keyed to the camshaft so you can hold the gear while you tighten the bolt to press the gear back on.
To install the crank gear, I used the metal pipe from a jack stand and tapped it back on.
The timing gears are a matched set so don't even think about taking a short cut and only replacing the camshaft gear.
All,
I got the cover off. All I had to remove was the harmonic balancer, fan and clutch and water pump. So far it's been pretty straight forward.
While the timing gear had not completely disintegrated, it is missing teeth from almost half of the entire gear. All in one patch, too.
My new gears are in. I'm hoping to install soon.
I just hope this solves my knocking issue, as well. If not, I'll pull it and rebuild her. But I'm hopeful that is not necessary.
F150xlt,
I have another question. I got the new timing gear on, no problem. However, my crankshaft gear has three cut outs for a keyway. I've got the crankshaft gear in place and the dots aligned.
However, how do I know for certain I've used the correct keyway on the timing gear? I want to ensure my #1 cylinder is TDC and the valves are doing what they're supposed to before I put all this back together.
I think I have it all on correctly. But I sure as hell don't want to discover that's not the case after I put everything back on. I don't believe I turned the crankshaft, but I want to make sure everything is copacetic while I still have her torn down.
Your aftermarket timing set allows you to advance the timing by using a different key way. Example if you used a different key way when the dots match cylinder one piston would be set at 3 degrees Before Top Dead Center
instead of zero degrees.
There should be instructions in the box explaining what the different key way positions do.
Change the oil and see if any fiber gear material drains out. Some larger chunks may be stuck to the oil pickup screen. Only way to clean them out is to drop the pan or just drive the vehicle and monitor the oil pressure.
Here's a picture of the key way you should use in relation to the dot on the gear.
#28
All,
I have the truck back together and she purrs pretty well. No knocking noise
Well, at least until I came to a stop at a red light. The rpm kept dipping and rising, but finally evened out.
However, there's definitely a knock coming from the timing cover. My question is, was I supposed to run a bolt and washer into the cam shaft to hold the cam gear in place? I don't remember taking one out.
I ask because I got the gear back in place and closed her up. She runs well, but after coming to a stop after cruising a while, she idles at 1100 rpm (same as before timing gear replacement), but there's a knock from the timing gear. It sounds almost as if the timing gear is tapping the cover.
However, once I blip the throttle, it goes away. It's not a continuous knocking, by any means.
Any thoughts on what this could be? Do I need to pull her back down and press the cam gear on further?
