extremly rough idle - Ford Truck Enthusiasts Forums
extremly rough idle
Old 05-20-2014, 09:42 PM
Jerryfx4 Jerryfx4 is offline
Jerryfx4 is starting off with a positive reputation.
extremly rough idle
How's it goin guys. I've done a lot of searching and haven't fixed the problem yet. a week and a half ago I went out to my truck to go somewhere and I got about 2 blocks away and the truck started running really rough and had a big lack of power, so I turned around and scanned it with my code reader and the codes I got were p2271, p2196, p0303, p0012, p2197, and p2272. since then I've changed all the spark plugs, boots, swapped all the coils and injectors from a great running truck, fuel filter, and the bank 1 upstream O2 sensor.
the other thing that came to mind that could of caused the problem is that a few days before the problem started. I jump started a co-workers car and he hooked the cables up backwards on his car. Could this be the cause of the problems I'm having.
The truck is an 05 F150 FX4 5.4 with 180,000 miles on it.
any help would be greatly appreciated
Old 05-21-2014, 02:37 PM
anyone have any ideas? how can I tell if its the cam phasers? I don't want to keep throwing money in to this thing if it doesn't fix the problem.
Old 05-21-2014, 03:06 PM
bra$$monkey's Avatar
bra$$monkey bra$$monkey is offline
bra$$monkey is starting off with a positive reputation.
the first two codes are O2 sensors - they wont normally make the truck idle poorly.
P0303 means a misfire on the number 3 cylender
P0012 - camshaft timing is retarted - on a variable timing cam - this means the VCT solinoid failed - which is probably the cause of your P0303 if it leaves the valve open you get the misfire.
P2197 & P2272 - another O2 sensor
Check this out on how to replace
http://www.google.com/url?sa=t&rct=j...uAooKCFRfVyZaw
Old 05-21-2014, 03:10 PM
oh yeah - the jump start didn't hurt anything.
Old 05-21-2014, 03:28 PM
is there anyway to test the VCT solenoid to make sure it failed or is the only way to replace it?
Old 05-21-2014, 04:01 PM
could it be the cam position sensor on bank 1?
Old 05-22-2014, 10:10 AM
Any advice guys?
Old 05-22-2014, 11:10 AM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
You lucked out if its on bank one for the vct solenoid anyways since its the easiest too get too. I would just go ahead and spend the 50 bucks and get the solenoid and also get a new cap. Usually if its the cam shaft position sensor it will kill the truck and not cause a rough idle
Old 05-22-2014, 02:18 PM
I changed the vct solenoid and the truck is running good. Thanks for the help fellas!
Old 05-22-2014, 11:47 PM
Quote:
Good deal! Glad if we were of any assistance
P2195, P0059, P1000, P0330, U0121, P0351... so many codes!! Please help!!! AGrayson84 Expedition & Navigator 4 11-01-2016 10:35 AM
2001 f350 super duty 4x4 71offshore 1999 - 2003 7.3L Power Stroke Diesel 4 09-01-2015 08:37 PM
Too many DTCs all at once. NovaNewfie 1997 - 2003 F150 2 03-09-2014 11:04 AM
02 F450 Runs rough, stalls when warm Shepherd2 1999 - 2003 7.3L Power Stroke Diesel 3 02-26-2014 06:03 AM
2000 F150 5.4 running rough richis69mach 1997 - 2003 F150 1 04-21-2010 12:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
