Starter / Bendix problems....
1974 F-100... straight six 240 ... C4 automatic trans.
my current issue is that i am on my 3rd starter and havent figured out my issue. majority of the time when attempting to start i will get the dreaded grinding noise. with the lower inspection plate off the tranny, its clear the flexplate is not spinning when this happens.
bought the truck a couple months ago and this started. purchased a new starter and when i went to replaced found the top bolt hole stripped and flex plate had some damaged. pulled the trans and replaced flex plate and had bolt holes re-done by local machine shop.
i also moved onto 3rd starter since bendix gear was chewed up. also replaced starter soliniod and checked battery.
still stuck with a truck that will rarely turn over properly and cant drive...
what am i missing, i feel like i have replaced everything.
Kyle Wood
22
09-06-2023 08:23 PM
'74 Ford 250 CS
04-19-2016 09:51 AM
VanBourne
06-16-2014 10:45 PM
