2000 Ex Skin Cancer
2000 Ex Skin Cancer
I am having problems with the paint coming off the roof and it resists any attempts to repaint it. The primer does not seem to want to take the paint. I guess it is a non-porus epoxy primer of some sort. Is there a primer that will let new paint stick to the old primer? The paint on most of the truck looks pretty good but once water gets between the top coat and the primer it starts to peal. I have been using Dupli-Color which is not the best. The solvents are too hot and it hardens before it has time to adhere. I am trying to avoid painting the whole truck which will cost more than the truck is worth.
Perry
Perry
Same issue with my 2000 ex! The paint peels! Figuring I need to repaint.
Greenish primer underneath. As you say, seems like an epoxy primer that just won't take paint. Once the water gets under the topcoat just seems to peel. Pressure gun at the carwash started it. Seems particularly bad at the door jambs.
Would be interested if we had similar VINs - you know, manufacture plant, date code.
Its gonna take a new paint job...
norvillebob
02-03-2010 01:00 PM
