Axle code
3.55 in a 1 ton 4x4 with a big block? Was that an option or has my axle been swapped? I was expecting something closer to 4.10s.
Received 3,103 Likes
on
This now brings up another question if anyone has any input. I tow a travel trailer that weights 7200lbs dry and about 7500-7700 lbs with water and gear.
Can I using the same axle change my gearing to like a 4.3 set-up? Is their like a kit you can buy online for all the correct parts
so that I can swap out the gearing? Is it super expensive for parts?
EDIT- Just thinking now, its a 4wd does this mean I'd have to change the front as well?
EDIT- Yes I'd have to change both & wow that's pricey. 1100$ and I'm not sure if I could do the gear lash adjustment or not.
https://www.nitro-gear.com/Ford-Supe...-10-select.htm
easy.
Loganwildman
10-08-2004 09:59 AM
64_f100_owner
03-03-2004 08:40 AM
