56 gas gauge, help an idiot . - Ford Truck Enthusiasts Forums
Old 05-20-2014, 06:22 PM
DR Smith's Avatar
DR Smith DR Smith is offline
DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.DR Smith has a great reputation on FTE.
Ok I know gas gauge problems have been talked over for ever . I have tried the search feature and have not gotten the information I need . The truck is a 56 F250 , stock gauge , aftermarket wire harness , Bob Drake sending unit sold by Midfifty . When I turn on the ignition the gauge goes to full . I have checked the gauge out of the tank , 10 ohms full , 94 ohms empty . Gauge has 12 volts going to it . checked wire from sending unit to gauge , 0 ohms when ohm meter probes hooked to each end , There is no voltage regulator for the gauges , can't find one . Am told 56 was first year for 12 volts going to gauges , also none shown in wire diagram . If gauge was grounding out through the dash , gauge would show full with sending unit wire unhooked , It does not . Now I have read in my search on this site that the ohm reading on the sending unit should be 10 ohms empty 73 full . That is opposite of what Midfifty is telling me . At this point , I have hit the brick wall . So tell me what I need to do .
Old 05-20-2014, 06:41 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe Jolly Roger Joe is offline
Just another Joe
Jolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud ofJolly Roger Joe has much to be proud of
Here's the Information sheet from Mid Fifty on their sending units. Doesn't look like any of them match your readings.
What was the model number you got from them?
Name:  SENDER OHMS - INST-2690-OHMS.jpg
Old 05-20-2014, 06:46 PM
DR Smith's Avatar
mine is a 1607-56 one year only . Bob Drake number on the unit 99A-9275
Old 05-20-2014, 07:00 PM
Just another Joe
Bob Drake's site shows that number for '36-'56. "6 or 12 Volt, For use with original Ford gauge only. This high quality sender is adjustable from 6in. to 23in. of measurable depth."
I don't see how that could be right if the '56 was different from the rest.
https://www.bobdrake.com/ItemForm.aspx?Item=99A-9275
And I found one for sale on eBay that says it's for the '36 - '55. His readings are almost like yours: 10 ohms full, 100 ohms empty.
Old 05-20-2014, 07:12 PM
DR Smith's Avatar
THATS one of the problems , The information I am getting is all over the place . who do you believe . I have a 56 car shop manual and it said if you put 3 volts to the gauge it would read 1/2 full , 4 volts will show 3/4 full . at that rate 12 volts would show full twice . I checked three other vendors and they all show 56 sending units as a stand alone item .
Old 05-20-2014, 07:21 PM
Just another Joe
Wish I could be more help. I don't know anything about '56 trucks... except that they are a beautiful design.
In my Google searching, I saw something about differences between car and truck sending units, so maybe that shop manual data doesn't apply to trucks.
I'm probably just confusing you more. I'll bow out and let someone who knows what they're talking about help you figure it out.
Good luck.
Old 05-20-2014, 07:35 PM
DR Smith's Avatar
Thanks for trying , I did find a old post from Numberdummy , that stated the 56 sending unit was only used in 56 .
Old 05-20-2014, 08:04 PM
Just another Joe
You probably found this too, but it confirms that '56 gauges and sending units are unique.
"In 56 when Ford went to 12 volt systems the same pulse sender design was used but redesigned to work on 12 volts. In 57 for some reason Ford went to 6 volt gauges again and began using the constant voltage regulators (CVR) to drop the voltage for the instruments. Starting in 57 all sending units were changed to the resistance type.
So 56 gauges are very unique being 12 volt and not generally compatible with other years."
http://www.ford-trucks.com/forums/74...ding-unit.html
Old 05-21-2014, 12:41 PM
DR Smith's Avatar
It gets more confusing , I called Bob Drake , as the sending unit I bought from mid fifty is a bob drake with part number 99a-9275 . Their on line catalog shows this fits 35-56 ford trucks , but if you go to the 56 site they have a sending unit as part number B6C=9300 . The person I talked to had know Ideal why they had 2 different part numbers or if they really where different . Does anyone know for sure what the empty and full ohm readings should be ?
Old 05-21-2014, 01:43 PM
raytasch's Avatar
raytasch raytasch is offline
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
Ok Dave, I just went out and checked the sending unit on Missy Green. The wiring and gauges are original AFAIK. Last time out I filled the tank and it has probably a gallon burned out. My reading with a good Fluke meter was erratic, between 150 and 90 ohms. I believe there is a heater strip in the float itself that the meter battery is heating, thus the fluctuation. BTW, wire to the gauge was disconnected for the reading. Frustrating, ain't it.
Edit: And as I told you in our PMs, my gauge is no longer accurate. Gauge is reading 1/4 tank with those readings.
Old 05-21-2014, 02:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Here's what the 48-52's used, I don't think it's significantly different on later models.
Old 05-21-2014, 03:53 PM
DR Smith's Avatar
Ray my sending unit reads 94 at empty , your seems to be 90s at full . Ross the wiring is the same ,but 56 was a 12 volt gauge , in 57 they went back to 6 volt . so I don't know if the sending unite is different for 56 , All the vendors show a 56 only unit but nobody can tell me what the difference is .
Old 05-21-2014, 04:12 PM
bmoran4's Avatar
bmoran4 bmoran4 is offline
bmoran4 is gaining momentum as a positive member of FTE.
Quote:
For those having issues with your stock fuel gauges and new tanks, it's because there are two different "languages" being spoken. Most modern fuel gauges and senders are simply paired ohm meters and variable resistors; the gauge measures the resistance of the sending unit circuit which changes with the fuel level.
However, our stock Ford trucks used a different language, named The King-Sealy principle. These sending units supply a full 6V through a heater wire in the gauge in the form of a square wave with the duration of the "on" being the variable determining the gauge reading. The longer the duration, the more fuel in the tank. It is this full 6v of current which heats the bi-metallic strip in the stock gauge that causes the gauge to read via a small gear train. Most (if not all) after market sending units are simply a variable resistor which sends a constant closed circuit of varying resitance to the gauge. Therefore, the sending units signal doesn't heat the bimetallic strip in the gauge as much making the calibration of the after-market sending units and the stock gauges nearly impossible to match up very well due to the differences in the principle of the signal.
Modern gauges are easy to pair as long as the sending units full and empty ohm readings match that of the modern gauge. Some senders and gauges are even highly adjustable in this regard.
I should note that my knowledge goes for the stock 48-52 trucks, but I think the next generation, minimally through 55, used 6v gauges with resistors.
Old 05-21-2014, 05:27 PM
raytasch's Avatar
So, can we conclude that reading the resistance of the sending unit accurately is not possible with a VOM due to the heating coil?
Anyone else notice the 6 volt battery is wrong polarity in the schematic shown above? Not that it has anything to do with Dave's problem or operation of the circuit.
Old 05-21-2014, 05:33 PM
bmoran4's Avatar
So, can we conclude that reading the resistance of the sending unit accurately is not possible with a VTOM due to the heating coil?
Affirmative - the correct proceedure for testing the stock sender is testing against a known good gauge. Expanding on that idea leads to this: For example, if you have a funny oil pressure reading, test your oil pressure gauge. If the gauge passes the test, the sender is suspect (provided your wiring has not deterioated).
All 48-52 stock gauges (fuel, temp, oil pressure) can be tested with 2 D Cell batteries. 1.5 volts does 1/2 swing, 3 volts full swing.
The image ALBUQ F-1 posted is for 48-52 trucks which were positive ground. Polarity does not matter for the King-Sealy gauges.
Help finding sending unit/gas gauge that are compatible. ford5.8 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 10-19-2016 07:18 PM
1947 Gas Tank Sender again triumph1200 1947 and Older Ford Trucks 16 08-25-2016 10:42 AM
Fuel Tank Sending Unit rswhitmore 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-20-2015 11:27 AM
Factory resistance values 1930 Dodge 1948 - 1956 F1, F100 & Larger F-Series Trucks 26 02-01-2013 02:50 PM
Fuel Sender unit "22 ohm resistor"??? scarl Electrical Systems/Wiring 4 09-07-2003 09:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
