1990 F-250 TTB
1990 F-250 TTB
Hi Everyone,
I just added a new truck to my garage, 1990 F-250 xtra cab 4x4, with a TTB front end, 460 & 5 sp manual trans, & a 4" lift.
It does have a problem with the front end:
When driving forward the alignment is (looks correct), but when I back up, the front tires toe in & get a massive negative caster (top of the tire leaning in). The truck doesn't wander, & no death wobble.
Any thoughts on what might be causing this?
Thanks,
NT
Thanks,
NT
It's very normal for the front suspension to shift one way when backing up and another when going forward (I'm 95% sure it squats backing up and sits higher going forward). Because of the geometry that inherently changes the camber (leans the tire in at the top as it squats, caster is tipping the steering knuckle axis front or back).
However, if your tie rods are lined up with the traction beams as they are supposed to be there isn't much change in toe-in as the front suspension cycles. If the truck has been lifted without using a drop pitman arm it could cause toe-in to change a lot as the suspension cycles.
Thanks for the fast response guys..........
I think I found the problem:
The lift kit has the drop down brackets for the axle pivots, the one for the passenger side has only 1 bolt holding the bracket ( there are supposed to be 5). It looks like its swiveling, causing the steering geometry to move in a weird way. I will take a pic & post it up.
Thanks,
NT
Thanks,
NT
mustanginca
15
02-02-2011 12:40 PM
4tl8ford
06-28-2008 08:30 PM
