Master cyl line removal
Ed:
I agree with most of what you indicated. However at the slave cylinder that approx 3" sleeve assembly is also affixed to the slave cylinder by a pin - that is what fordka referred to as dismantiling. When that is dismantled the fluid will drain, like he indicated. Otherwise I agree with the rest of what you indicated, went thru basically the same ordeal ....
eallanboggs
05-23-2008 09:58 AM
