F150 4.6 2v Supercharger-Turbo - Ford Truck Enthusiasts Forums
Old 05-20-2014, 12:30 PM
barajas409 barajas409 is offline
barajas409 is starting off with a positive reputation.
Hey guys i got a 2003 f150 4.6 2v. Looking into getting a supercharger or turbo setup for like under 3 grand only want like 5-7 pounds of boost. any ideas? #f150
Old 05-22-2014, 01:07 AM
bump . . . . . . .
Old 08-06-2014, 12:47 AM
78Jimmy 78Jimmy is offline
78Jimmy is starting off with a positive reputation.
bump......... sorry, just doing the same build, so hoping to get some info..
Old 09-06-2014, 06:32 PM
Ford'05HG's Avatar
Ford'05HG Ford'05HG is offline
Ford'05HG is gaining momentum as a positive member of FTE.Ford'05HG is gaining momentum as a positive member of FTE.
I can tell you now that a supercharger won't be available for under 3 grand. At least, I've never found one. However, turbo charging might work well for that motor. It's all about how you set it up and what kind of things the motor needs to do.
I'm gonna build one of these for a ranger hoping to get an 11 sec car while keeping it a daily, so ill be doing big turbo and big cams. That will put my power band at a better for racing 5000rpm band.
But If you are towing you won't necessarily need cams or a big turbo, just a slight timing tune and some decent twins should give you a good low end build. It's all about what you are wanting out of it.
Old 11-23-2014, 10:21 AM
UNTAMND's Avatar
UNTAMND UNTAMND is offline
UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.UNTAMND has a great reputation on FTE.
Custom building a turbo setup will be your cheapest route.
Find an oem turbo, and buy quality wastegate and bov, you should be fine.
3k is a good budget. I could build you one for that cost if you were closer to Philidelphia PA.
2003 F150 4.6 2v Supercharger-Turbo barajas409 1997 - 2003 F150 0 05-23-2014 01:36 AM
4.6 supercharger? Masterc333 1997 - 2003 F150 11 06-28-2012 01:48 AM
Supercharger Fasttimez 2009 - 2014 F150 9 07-21-2011 09:16 AM
Info on supercharging my 05 4.6L Goose05 Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 0 06-09-2008 12:37 AM
Ford F-150, 2004 Supercharger vs. Turbo Charger krogh Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection 3 02-13-2006 01:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
