best automatic trans&transfer case for 351w
Received 3,090 Likes
on
on
If you plan on running bolt on long tube headers for that chassis, do not use a 205 unless you also backdate to a 70's front axle. Pinion, and transfer case output location changed by 4" 79 to 80, and a 79 and older runs the front driveshaft on the inside of the exhaust, 80 and newer the driveshaft is on the outside. With a 205 you end up with the driveshaft taking up all the space under there and no room for headers designed for the chassis.
I abuse a 1345 in my 44 shod toy and have for the last 12 years. I have never had an issue. The low range is much better, and they shift like butter compared to a 205. My 205 does not cooperate nicely.
mikepedersen17
06-03-2014 08:16 PM
whisler
07-16-2012 01:01 PM
mustangman65_79
02-11-2012 03:23 PM
rsalter66
08-30-2007 08:25 PM
