Well, the floor plate didn't go as planned. This is the adjustable column mount floor plate from midfifty. My brake arm is about 1.5" to the left of where it should be. I have the cpp brake booster under cab bracket. Not sure why it offset
J: My pedal assembly was from Speedway, and my booster/master from POL. I had the same problem, to align the pedal, I bent it. Works like a charm and doesn't effect the travel or braking force. Good luck.
