Picking up the Survivor this weekend!
There are tricks in the trade to verify mileage....maybe do a little googling. One I remember is checking the wear on the rubber brake pad. High wear would indicate 148k or 248k. No wear would indicate it was replaced (easy to do) and probably was also at least 148k. The best scenario is if it has very slight wear...indicating 48k.
It sure is a nice looking truck, but it seems like a guy who keeps his truck and has it set up for trailering would put some heavy miles on it. Driving it is also an excellent clue.
Overall I think you just may have a winner!
I will be taking the bed off, and sandblasting the underside, frame and suspension before winter hits, because if I don't...that sucker will rot through in no time with these MN winters. Then i'll focus on getting the front done after that.
As far as the alcoas go...not really too big of a fan of those. They look good on the 92-97's, but on an 86 I don't think they match up well. At least that's what i'm mentally projecting.
Well guys, I did it and it's back safely.
Picked it up on Saturday and got it home and immediately started working on it.
The good:
- It has one of the rare aluminum insert tailgates
Similar to what diesel_brad posted a while ago
- It is in great shape
- Dash pad is 99% perfect
- The cruise actually works!
- The motor is very strong and sounds very healthy
- Took the running boards off and luckily there's no bad rust surprises waiting for me underneath them
The bad:
- Passenger side window motor is out, i'll be replacing that this weekend
- The PO drilled through the roof to mount his visor, so those bolts are rusting and need to be removed and welded shut before it gets any worse.
- The frame has surface rust beginning, I plan to take off the bed first and sandblast it, then Rhino-line the inside and underside of the bed, then POR-15 the frame and suspension before that gets any worse.
- Since the PO used it for hauling a camper, he had made a custom overkill bumper that i'll be replacing with an original soon, I also need to find the tailgate mounting hardware because he took it off to fit the camper and it wasn't given to me when I bought the truck.
- I figured since this is a Lariat, it MUST HAVE overdrive....nope . So I need to find a nice auto 4 speed for it.
- Coolant temp gauge doesn't report anything on the cluster.
- It bounces REALLY bad going down the road, like VERY bad. My dad says, "it'll do that if you don't have weight in the back"...while i'm very familiar with his 2500 Ram V10 not being the most comfortable to drive down the road, it still rides better than my new truck, so I need to figure out what's going on with that.
- I'm thinking the dual smog pumps need to go.
- Old bad gas needs to get drained and refreshed.
- Carburetor needs to be rebuilt after having run all the old nasty gas through it.
I'll be posting some more pictures tonight once I get home.
The good:
The bad:
#28
My F250 was the same; & it was also set up from new with Heavy Tow & Camper packages.
Removing the sway bars makes a big difference on rougher roads.......with them on, the suspension is pretty rigid.
But, as your Dad says, some weight in the back helps too.
#29
#30
I took it out last night and got some fresh non-oxy gas in the rear tank. Carb definitely needs to be gone through. Died on me a few times, but once it's warm, it runs fine. Can't mash the throttle otherwise it falls flat on its face and dies.
It also rode MUCH smoother last night, wasn't bouncing or jumping all over the place at all. Also, the 3 speed was MUCH smoother and more fun to drive than before. I took it out on it's first drive in 10 years on Sunday, and that's when all these problems seemed to arise. Now they all seem to have gone away and everything is normal. Maybe it just needed to get used to being driven again?
No need for a 4 speed auto, looks like the C6 will suit me just fine. I also discovered that as long as you keep your foot out of it, it gets acceptable mileage.
Martin Torres
21
03-01-2018 09:12 PM
Ford4x4-JD70AB
12-15-2008 07:59 PM
