Which chip/programmer to increase tow power on 2005 F150 4.6L? - Ford Truck Enthusiasts Forums
Old 05-19-2014, 10:48 AM
kenp2600 kenp2600 is offline
kenp2600 is starting off with a positive reputation.
I used to pull my 29ft camper with my 01 expedition with a 5.4L engine. I got a new truck last fall and we're getting ready for camping season. This is a 2005 F150 with only a 4.6L engine. I can tell just by pulling up my driveway to test, it's not going to have as much power on the hills as expected.
I don't have a large budget (really no budget but I will do what is necessary) so can someone recommend a chip or programmer that I will see decent results when towing, but that won't cost too much? I guess I'm looking for the best bang for my buck but I don't need to create a race car, just get my camper up the hill easier.
In addition to just being a less powerful engine, it seems like it never wants to downshift into "passing gear" when I'm pulling and above around 40mph. This may just be how the truck is geared but I'm not sure if that is something extra I need to worry about or not.
Thanks all,
Ken
Old 06-10-2014, 08:08 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Hate to break it to you but you can't program in more torque on a naturally aspirated(non turbo) engine, you can program higher shift points and get a little bit more peak horsepower but that won't make any difference at lower rpms.
Old 08-28-2014, 05:37 PM
tee4 tee4 is offline
tee4 is starting off with a positive reputation.
Which chip/programmer to help motorhome with V10?
Old 09-01-2014, 04:36 PM
Anyone out there have a Motorhome with a V10?
I could use some help getting more perfomance out of it.
Old 11-03-2014, 08:36 PM
Duderoy's Avatar
Duderoy Duderoy is offline
Duderoy is starting off with a positive reputation.
torque??
Quote:
What??? everything I've read about every tuner shows how much torque and HP will be gained. I can change timing alone and change torque curve on ANY engine. I guess I'm curious about the no torque increase on naturally aspirated. What is the logic or reasoning.
Old 11-04-2014, 07:53 AM
RIKIL's Avatar
RIKIL RIKIL is offline
RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.RIKIL has a great reputation on FTE.
Quote:
I'm going to guess you read about the increase in torque from the same sites that are selling the chip? For what you want to do, you need to change something on your motor first to get you the torque then you tune the computer to work with it.
Old 11-04-2014, 09:19 AM
Conanski's Avatar
It's simple, as it stands the EFI systems on these newer motors is designed to maximize output at all rpm, the computer already applies as much ignition advance as the engine will tolerate under the given conditions so there is really nothing to be gained with a chip or tuner... especially at lower rpms where total ignition advance is limited by detonation. On early OBD1 systems there is some room for improvement with ignition timing but that still only applies to unloaded and non towing conditions, hang a trailer off it and you will have to back the timing down again to prevent detonation.
Old 11-06-2014, 09:28 PM
Duderoy's Avatar
Emissions
Emissions man, emissions. They are tuned to an allowable performance that meets low emissions standards. Their are always ways to mod performance with tunes. maybe not allot , but they can improve. Wow you must really hate tuners.
Old 11-09-2014, 08:48 PM
Conanski's Avatar
No I don't hate tuners I have one for my '90.. a Tweecer RT.
Sorry man you have been fed a pile of old wives tales, that is simply not the case.
Yes.. exactly, some gains can be had but in the big picture it isn't enough to justify buying a tuner for an otherwise stock motor.
Programmer/Tuner/Chip birdboy 1999 to 2016 Super Duty 5 02-20-2016 05:48 AM
howdy, , , again. Louis Angel 1987 - 1996 F150 & Larger F-Series Trucks 2 09-17-2015 06:05 PM
460 headers darren_palms 1973 - 1979 F-100 & Larger F-Series Trucks 9 03-18-2014 11:37 PM
460 Headers Or Manifolds darren_palms Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 03-16-2014 08:11 PM
Gains from bolt ons? raccol 2004 - 2008 F150 37 09-08-2006 05:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
