05 axles in a OBS
05 axles in a OBS
So I have decided to sell my ECSB and buy a CCSB. I want to swap in 05 axles when i bug the truck so today i bought a 2005 rolling chassis to do coils up front and a 10.5 out back. I am perfectly comfortable with getting the axles under the truck that is not my problem. The area i lack knowledge in is the brakes.
I have a few questions, hope yall can help.
1) obviously i need to adapt the brakes (front and rear) to the OBS lines. But i dont know the thread pitch of either the OBS brake lines OR the 2005 brake lines. So what adapter fittings or flare nuts would i need?
2) i have read about people who have done the swap and the rear brakes lock up quickly because the 10.25 drum brakes require different pressure than the 10.5 disc brakes, so if i were to install a proportioning valve, what model and thread pitch would i need to make this work?
Ill figure out the parking brake.
Thanks yall
Aaron
Thanks yall
Aaron
There's a very good write up over at psarmy.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Received 3,090 Likes
on
Richard
on
FOUND IT!
I was having issues because it wasnt on FTE! lol
This would be awesome.
06 Axle swap, the whole story - Ford Powerstroke Diesel Forum
However, for that much work... I'd probably just keep the 6.0 drivetrain and put an OBS body on it.
Ok... I found some of the info on the hydroboost...
Yes the brake pedal in hydro boosted trucks are different than vacuum.
"the pedal pin on the F-Superduty is indeed 3/4" closer to the pivot than the vacuum-boosted one"
What this means is that if you use the same brake pedal it will be harder to brake.
I am looking for the details on the other hydroboost assembly (from a f-53 chassis iirc) that came up in one thread but cant find it yet (I forgot to bookmark it).
Richard
EDT: here is a link to a guy that converted the pedal....
http://powerstrokenation.com/forums/...d.php?t=196241
Richard
