Torque Pro users: NEW Gauges! - Ford Truck Enthusiasts Forums
Old 05-18-2014, 07:30 PM
diesel_dan's Avatar
diesel_dan diesel_dan is online now
FTE Addict
diesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to beholddiesel_dan is a splendid one to behold
Figured I'd just start another thread, since this is more than just the Sync subject I had the other thread on.
They work! both the calculated Delta Temp "gauge" for oil vs. coolant temp and the Cam to Crank Sync. work! On top of that I found (maybe most of you already know this), is just delete the old Boost gauge and rename the "Ford Specific Boost" that is now in our Ford Extended PID set, which shows up with a gauge name of MAP, to "Boost" and use it instead. Some folks will be fine with the name MAP, to each their own, but the new one doesn't do the weird Boost to Vacuum back to Boost flip flop under full boost like the other one does.
Here ya' go:
Cam to Crank Sync:
You need to Start at the top level of the main screen and go to menu and pick Settings. From there you go to Manage extra PIDs/Sensors. Hit Menu again here and then Add custom PID.
PID is: 2209cd
Long Name: Cam vs Crank Sync (pick your own if you don't like that)
Short Name: Sync
Minimum Value: 0
Maximum Value: 1.0
Scale Factor: x1
Unit Type: Sync
Equation: {A:1}
OBD Header: 7E0 (that's a zero)
That's it. Once you have added it you can go add it to your real-time display screens, logging, whatever. I chose the gauge that is On/Off (near the bottom of the list). Once Torque is connected to your ODBII device and you turn to KOEO, the dash mark in the gauge will turn to "Off" (and the gauge color red). Once you start cranking it should go to "ON" and turn green (or you've found your no-start problem ). It's always green and ON when running (as we all hope).
Now, I have yet to find or hear from someone that is able to see both Cam/Crank and have a separate FICM Sync (they all seem to be using the same PID, which means it's the same thing they are looking at). If someone can help on the FICM Sync, that would be super...
Calculated Oil Temp to Coolant Temp Delta:
Follow the above directions to the Add a Custom PID point, then:
Leave ODBII PID blank
Long Name: Delta Temp (or whatever floats your boat)
Short Name: C/O Delta (or O/C Delta, what you want to see in the gauge)
Minimum: 0.0
Maximum: 30.0
Scale factor: x1
Unit Type Deg F
Equation: (([221310]*1.8)+32)-(([05]*1.8)+32) NOTE: This is now the CORRECTED formula
leave the rest blank, select OK and choose the gauge type you want from one of your real time screens. You can log this, display it, alarm on it or you name it. It will be negative when oil temp is less than coolant and then positive when oil temp is greater than coolant (normal). Super easy to glance at and see what the delta is w/o taking attention off the road
Enjoy....
Oh yes: full disclosure: I just found these elsewhere and tested them -- I'm not smart enough to come up with this stuff on my own
Old 05-18-2014, 08:24 PM
Money-Pit's Avatar
Money-Pit Money-Pit is offline
Money-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to beholdMoney-Pit is a splendid one to behold
I'll be damn....I emailed the developer a couple months ago about adding a "delta" gauge....he listened. Too cool.
Old 05-18-2014, 08:55 PM
Money-Pit's Avatar
Something isn't right..my eot is 107.5 ect is 104 and I'm showing a delta of -43
I've doubled checked the formula, it's as Dan has written... can someone else see if it works?
Old 05-18-2014, 09:14 PM
diesel_dan's Avatar
FTE Addict
Money! I found it - typo it is, and thanks for catching it... Here's the right equation (was missing a digit...)
Let me know if that works for ya'...
Old 05-18-2014, 09:22 PM
cope1972 cope1972 is offline
cope1972 is starting off with a positive reputation.
How did you get yr icp and ipr gauge come up? I haven't been able to get it on mine...
Old 05-18-2014, 09:25 PM
lupuseven's Avatar
lupuseven lupuseven is offline
lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.lupuseven has a great reputation on FTE.
Subscribed you awesome thank you.
Sent from my SPH-L900 using IB AutoGroup
Old 05-18-2014, 09:26 PM
Money-Pit's Avatar
Thanks buddy! It works now.
( you also snuck that second to last character (2) in there)
lupuseven's Avatar
Here ya' go:
Cam to Crank Sync:
PID is: 2209cd
Short Name: Sync
Minimum Value: 0
Maximum Value: 1.0
Scale Factor: x1
Unit Type: Sync
Equation: {A:1}
Minimum: 0.0
Maximum: 30.0
Scale factor: x1
Unit Type Deg F
Equation: (([22130]*1.8)+32)-(([05]*1.8)+3)
Enjoy....
I'll rep ya big time when I get home next week. This is awesome thanks for sharing it with the rest of us.
Old 05-18-2014, 09:29 PM
Money-Pit's Avatar
Quote:
Icp was originally called HPOP, I just changed the title. Ipr was probably the same deal although I can't remember what it was.
Old 05-19-2014, 12:46 AM
diesel_dan's Avatar
FTE Addict
I know Money -- I'm sneaky that way -- after a couple of G&Ts and coming off a road trip
But, being in Kalifornicanation, I could not post a screen shot like yours that showed just a few degrees difference between IA2 and Intake temp....
cuz, as stooopid as they are, the CARB folks love to fine (or is that find?) us...
Mine has to be like a bazillion degrees different or it throws codes and shoots flares out the back and lights up the mandatory "I am trying to get my truck to run right without your gawd awful emissions crap" neon lights flashing on all 4 sides....
But I digress....
Old 05-19-2014, 02:25 AM
Is there an equation or pid for hpop? I know when you select either icp or ipr I can't remember which one but it will come up as hpop. I'm trying to see if can have a gauge for all 3 hpop, ipr & icp.
Old 05-19-2014, 01:06 PM
diesel_dan's Avatar
FTE Addict
I'll try to answer what I think you are looking for:
yes: ICP (long name= Injection Control Pressure) has a short name of HPOP and reads in PSI (PID = 221446)
IPR (long name = Injector Pressure Regulator Duty Cycle), has Short name of IPR
and reads in % (PID = 221434)
ICP Voltage (that's the long name) is PID 2216ad, units are Volts. I think the 1st two are in the standard set of Ford Extended PIDs for the 6.0, this last one may be by now, but here's the rest:
Short Name: ICP V
Minimum Value: 0.0
Maximum Value: 5.0
Scale factor: x1
Unit Type: Volts
Equation: (((A*256)+B)*(72/10000))/100
ODB Header: Auto
Hope that's what you were looking for...
Old 05-19-2014, 01:47 PM
Exactly what I was looking for thank you!
Old 05-19-2014, 03:11 PM
flainn's Avatar
flainn flainn is offline
flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.flainn has a very good reputation on FTE.
Can you explain why these syncs are important to monitor?
Old 05-19-2014, 04:48 PM
Quote:
In my recent experience i did hpop, icp, ipr d-plugs & stand pipe install and my truck wouldnt start i believe if i'm correct if your ficm is not synced it can also cause a no start issue.
7.3L PIDs for 2016 - Torque Pro and others. Tugly 1999 - 2003 7.3L Power Stroke Diesel 134 03-01-2017 02:50 AM
Updated Torque PIDs Tugly 1999 - 2003 7.3L Power Stroke Diesel 204 12-18-2016 08:41 AM
Torque Pro FAQ Jaime74656 1999 - 2003 7.3L Power Stroke Diesel 59 11-12-2016 08:25 AM
2015.5 Torque Pro PIDs Tugly 1999 - 2003 7.3L Power Stroke Diesel 126 08-11-2016 09:11 PM
Custom PIDs for 2013 F150 5.0 cale10 2009 - 2014 F150 0 02-02-2016 01:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
