Torque Pro users: NEW Gauges!
Old 05-21-2014, 12:11 AM
73fan's Avatar
73fan
73fan is offline
Is your delta thing working? Mine is out no matter what I try ... by about 78°...
  #32
Old 05-21-2014, 02:22 AM
diesel_dan's Avatar
diesel_dan
diesel_dan is offline
Mine works perfect -- I had a couple of issues getting it typed in correctly to the forum here (thanks Money!), but it is spot on; then again I'm in Deg F -- have no clue how to make it work in C, other than what I guessed on (pull out the 32s)...
  #33
Old 05-21-2014, 04:36 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
My delta works too...your issue may be the C thing. Maybe try to set your preferences to F....see if it works. Then change it back to C.
  #34
Old 05-21-2014, 08:11 AM
wingrider75's Avatar
wingrider75
wingrider75 is offline
I set up the EBP as pictured, and still nothing. It acts like its not even getting a reading from the ECU.
  #35
Old 05-21-2014, 09:54 AM
73fan's Avatar
73fan
73fan is offline
To ensure accuracy, I copied and pasted the formula in. As for the 32 I've been trying different things and I can't get it right.
I may need to try that. If it still doesn't, it's not a big deal. Been without it so far!
  #36
Old 05-21-2014, 10:45 AM
diesel_dan's Avatar
diesel_dan
73fan: You did use the later corrected version, right?
I've gone back and corrected the 1st one I posted too, so now both Delta Calcs are correct (for us in Fahrenheit land anyway...)
  #37
Old 05-21-2014, 07:35 PM
73fan's Avatar
73fan
73fan is offline
Yeah I looked over it, it's entered correctly but still off. I'll keep fiddling with it till it's right!
  #38
Old 05-21-2014, 10:05 PM
Will Bite's Avatar
Will Bite
Will Bite is offline
My delta reads 84 deg. cant get it to read right.
  #39
Old 05-21-2014, 10:16 PM
Money-Pit's Avatar
Money-Pit
Just curious....have you guys updated the app lately? There's been a couple updates recently. Maybe that's the problem.
  #40
Old 05-21-2014, 10:19 PM
diesel_dan's Avatar
diesel_dan
Yet another GREAT point Money! Mine was set to only do updates when I was connected to WiFi (which I always had turned off).
Quite a few things have come down specific to us with some of these releases...
  #41
Old 05-21-2014, 10:27 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
2003 and early 04 engines do not utilize the EBP sensor.
If you have a late 04-07 then you have problems.
Josh
  #42
Old 05-21-2014, 11:41 PM
wingrider75
Josh
Its an early 04. Thanks for the info. Guess I'll stop wondering about it then...
  #43
Old 05-22-2014, 08:30 AM
Will Bite's Avatar
Will Bite
Updated and still no luck.
  #44
Old 05-22-2014, 08:50 AM
Money-Pit's Avatar
Money-Pit
Only thing I can think of is to make sure you have the PID entered exactly as DieselDan wrote it. I don't have my tablet with me right now, but maybe tonight I can post a screenshot of the PID as it's entered in mine.
Here's an enlarged view of the equation...
(([221310]*1.8)+32)-(([05]*1.8)+32)<O</O
  #45
Old 05-22-2014, 09:16 AM
Will Bite's Avatar
Will Bite
I've checked everything 10 times its exactly as posted.
Quick Reply: Torque Pro users: NEW Gauges!
