Dropped Front Axle Bump Steer
Old 06-20-2014, 10:22 AM
sssingo's Avatar
sssingo
sssingo is offline
bump steer on lowered beam
see pic 20 for the CPP drag link lowerign block
I tried driving straight after installing by dropped beam and yes it was scary. Heating up the steering arm sort it right out and then the CPP lowering block also helps a lot.
Old 06-20-2014, 03:23 PM
jbontke's Avatar
jbontke
jbontke is offline
I have a drop axle from PMT and it has some draglink 'raisers' that move the draglink up.
1953-1960 F100 CNC MACHINED TUBULAR DROPPED AXLE | pmtfabrication.com
You may want to call and see what PMT sells them for. I can't remember!
Old 06-26-2014, 08:39 PM
TireDood's Avatar
TireDood
TireDood is offline
I also have a 3" drop from Sid, as well as reversed eye main leafs, and every other leaf removed. I installed 4 degree caster wedges when I assembled the front axle. Sits pretty low, but I have no problems at all with bump steer. The truck sits almost perfectly level, the rear may be 1/2 in higher than the front. When figuring caster, don't forget to allow for that. If the rear sits higher than the front you need to add that to your caster measurement.
Old 06-27-2014, 07:23 AM
jbontke's Avatar
jbontke
jbontke is offline
How exactly do you calculate that? If you level the frame then set the caster, the raise in the rear causes the caster to increase (go positive), correct? So measuring the caster with all wheels on the ground is the correct approach?
Old 06-27-2014, 08:23 AM
5pointohh's Avatar
5pointohh
5pointohh is offline
I pretty much have the same setup! expect its a 56. I haven't drove the truck yet, but it sits great! this may be a bonehead question, but the shims you installed for the axle, the THICK part goes towards the cab, correct?
Old 06-27-2014, 02:18 PM
TireDood's Avatar
TireDood
TireDood is offline
I calculated mine by setting it on all 4 wheels with the drivetrain and cab installed. If you raise the rear the caster will DECREASE. Think of it like the front of a bicycle... Caster angle is measured from the center of the spindle through the topmost mounting point of the spindle (top of the kingpin). You always want the spindle farther forward than the upper mounting point. More caster is better, it will increase stability, but will also make it harder to turn the steering wheel. 4-6 degrees total caster is what you're looking for.
Old 06-27-2014, 02:19 PM
TireDood's Avatar
TireDood
TireDood is offline
Yes, thick part towards the cab.
Duellym
1947 and Older Ford Trucks
13
03-16-2016 05:59 PM
pro1963
1961 - 1963 F100 Unibody
19
06-04-2008 06:26 PM
BFOOTER03
09-28-2007 09:07 AM
fish-albuq
02-10-2004 01:11 AM
onelowzuki
16
11-05-2003 11:16 AM
Quick Reply: Dropped Front Axle Bump Steer
