460 build up
See post #5
Streamline the guide bosses, bowl blend.
On the exhaust side you will want to remove the thermactor bumps and work the short side radius.
Ford exhaust ports are notorious.
If you intend to try this yourself I'd suggest going to the Rein"car"nation High Performance website and signing up for the porting instructions and templates.
Rein"Car"nation High Performance / index 2
I am not trying to shill Scott's business, just trying to keep you from finding water and owning a doorstop with many hours invested in it.
im kinda getting that vibe.. yea my machinist is a bad *** and in a little town so the prices are lower.. less compitition i guess.. just found a set of rebiult 88 fuelly heads cheap... will hey work if i us the price adapters for the carbed intake.. and l&l headers for the 88 efi ttb front end headers...
They've got those three plates.
I have never used them, so can't say how they work to transition round intake to rectangular port EFI heads.
The CS-460 was only suggested as a simple way of putting a carb on an otherwise complete EFI engine.
The idea of $300, plus sealing the valley block-off plate, aligning four intake gaskets, having to buy a taller distributor and $700 set of headers seems like an awful LONG way to get around just doing the right work to the D3 heads.
IMPO you are completely wasting your time with stock pistons 65 thou in the hole, but I wish you the best sorting this out.
carlmaass
07-20-2011 03:05 PM
FordTrucksKickGM
03-12-2007 01:31 PM
Rustymuffler
02-17-2007 11:42 AM
leadmic
04-11-2003 10:21 PM
