460 build up - Page 2 - Ford Truck Enthusiasts Forums
460 build up
Old 06-08-2014, 12:27 PM
OrFordGuy OrFordGuy is offline
OrFordGuy is starting off with a positive reputation.
ok ill sell off the 69/70 sets and go find a good rebuildable set of 73-86 heads... really should have kept the originals at this rate..live and learn i guess.. thanks for helpin out.. do the heads need any work or just some gasket matching
Old 06-08-2014, 12:50 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
See post #5
Streamline the guide bosses, bowl blend.
On the exhaust side you will want to remove the thermactor bumps and work the short side radius.
Ford exhaust ports are notorious.
If you intend to try this yourself I'd suggest going to the Rein"car"nation High Performance website and signing up for the porting instructions and templates.
Rein"Car"nation High Performance / index 2
I am not trying to shill Scott's business, just trying to keep you from finding water and owning a doorstop with many hours invested in it.
Old 06-08-2014, 01:07 PM
thats ok i've got a a local machine shop thatll do port polish work for 200 per head plus the rebuild costs.. rather let someone with the skill do it right..
the wife wants a drag truck.. can i use the 77 block and 70 heads to build a drag motor.. i know slitly off subject.
Old 06-08-2014, 01:24 PM
pedant
At least they belong together!
'77 block is internal balance.
Just be aware if you think to swap flywheels or balancer spacers.
Old 06-08-2014, 01:34 PM
yea well aware of the balance issues.. learned that when i started doing motor swaps in high school..
Old 06-08-2014, 04:04 PM
pedant
$200 a head?
Wow, I wouldn't do those heads for that price... per cylinder.
Did I mention how much I hate iron dust and numb hands???
Old 06-08-2014, 11:05 PM
im kinda getting that vibe.. yea my machinist is a bad *** and in a little town so the prices are lower.. less compitition i guess.. just found a set of rebiult 88 fuelly heads cheap... will hey work if i us the price adapters for the carbed intake.. and l&l headers for the 88 efi ttb front end headers...
Old 06-08-2014, 11:14 PM
pedant
I forget what the chamber size is on the early fuelie heads.
The f3's flow better than carb heads.
small intake E7's, not so much.
Watch the valve reliefs in whatever pistons you buy.
Yes, you can use that adapter on a 1988 lower intake.
You need the intake as well as the heads.
Old 06-08-2014, 11:18 PM
no intake with heads but price has a new spacer adapter part ap37 that fits a stndrd intake..thrying to leave the stock pistons in it..
Old 06-09-2014, 04:45 AM
pedant
They've got those three plates.
I have never used them, so can't say how they work to transition round intake to rectangular port EFI heads.
The CS-460 was only suggested as a simple way of putting a carb on an otherwise complete EFI engine.
The idea of $300, plus sealing the valley block-off plate, aligning four intake gaskets, having to buy a taller distributor and $700 set of headers seems like an awful LONG way to get around just doing the right work to the D3 heads.
IMPO you are completely wasting your time with stock pistons 65 thou in the hole, but I wish you the best sorting this out.
Old 06-14-2014, 06:16 PM
looks like ill pull the busted 77 merc motor, steal those heads for my motor, rework them and then add the 69/70 heads to the 77 for our ranger 1/4 mile race truck..that seems the best route for what i have unless i can find some cheap aluminums...
79 F series ls swap Prostreet1967 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-23-2015 11:31 PM
Specs For Building My Lincoln 460? BigBlocker0248 1967 - 1972 F-100 & Larger F-Series Trucks 11 06-28-2015 06:47 PM
Help identifying the 460 i bought this weekend bushmstr02 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 9 04-14-2014 07:17 PM
Piston Indecision moonley FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 03-19-2007 10:07 AM
timing specs for a 1970 429/460??? icuhatn99 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 01-27-2006 11:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
