Dorman Valve cover gasket question
Instead of a positive lock for the injector connector, the Dorman has a wire clamp that doesn't even snap on. When you close it, it just sort of lays there. I wondered if I'd installed something incorrectly but don't see any other way to do it. It could be that the valve cover is a close enough fit that it'd keep the wire doohickey from coming adrift but I'm not real comfortable with it. Can anyone shed some light?
Received 3,692 Likes
on
None of mine would snap/lock. Called Dorman and they said there should be a positive lock and I may need to do some bending to get that to happen. I wondered out loud why no instructions to that effect.... Anyhow, I took everything off again and customized the wire holders. To anyone running into the same problem, you can get a decent lock by removing the wire from the connector and bending each arm back towards the main body of wire.....a lot! I hand-held it and bent each end back with a pair of pliers. I was afraid of breakage but nothing broke.
Thanks, fellas, for responding.
Dutter 2
18
06-23-2018 11:36 AM
blown14psi
02-16-2011 12:07 AM
DrtyJack75
10-05-2009 09:28 PM
