300cid/ 4.9l/inline 6: What KB blower should I use?
Hey guys, I know this may sound green but I wanted to ask reading all your knowledge here I can tell you would know. That and not to go to Clifford perfomance at all. Ok, now if I wanted to put a Kenne Bell Blower on the 4.9l what model would I use? Do you think I will have to fabricate to get her to fit? Hope to hear from you all, you alll sound like down to earth Blue ovals forever. Thanks, Stephen.
I would use the one that is a replacement for the Eaton M90, it is probably listed for the Pontiac Grand Prix GTP. You will probably have to do some significant fabrication to make it work, but it could be as easy as milling the top of an EFI upper intake flat and drilling some mounting holes or making an adaptor plate, then block off the TB holes. The weight of the blower on top of the intake + belt tension might be an issue if this is done. If you are running a carb you will have more work to do.
Trussonistephen
05-13-2022 03:35 PM
jason832
01-18-2015 10:08 PM
coolguy1419
42
09-14-2014 07:32 AM
KsCop
17
07-30-2014 05:58 PM
southernford
12-29-2001 05:57 AM
