first trailer hookup on the new truck - wiring issues - Ford Truck Enthusiasts Forums
Old 05-18-2014, 10:00 AM
contento contento is offline
contento is starting off with a positive reputation.
Hi all. I brought the trailer home this weekend to hook it up to my new 2011 F150 (EcoBoost with the Max Tow package). When I hooked up the 7 pin harness, I first got a "trailer wiring fault" error on the in dash screen then it said trailer disconnected. I thought maybe I hadn't seated the plug all the way. I've double checked and it seems to be plugged in well enough. I don't get the wiring fault error anymore but if I slide the brake controller on, I get the error popup screen that says trailer disconnected. I have brake lights and turn signals.
I used my multimeter to check the plug on the trailer (disconnected from the truck). I put the red probe into the power pin and tested all of the others (except the ground...didn't want to short something out) with the black probe. I get a good 12v on the turn signals and the markers, but on the trailer brake pin I only get like .32v. Is that normal? I figure there isn't supposed to be voltage to that pin except from the truck when the brakes are applied.
Then I tested the truck side with the multimeter and get 12+v on every pin (not the brakes). Then, as the brakes are applied, I get around 8-9v (same thing if the brake controller is engaged).
I jacked the wheel up on the trailer, spun the wheel and when the truck brakes are applied, I don't get any trailer brake engagement. I unhooked from the truck, spun the wheel and pulled the trailer brake emergency pin but still get no brake engagement.
So, to me, it sounds like there is something wrong on the trailer side beyond the plug. Sound about right? So, what would the right plan of attack be? What and where can I test continuity and try to track this down?
Thanks guys
Old 05-18-2014, 12:53 PM
r2millers's Avatar
r2millers r2millers is offline
r2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud ofr2millers has much to be proud of
Thanks guys
Here's a thread just practically below your's for voltage references. I agree that it's probably trailer side.
You should hear a hum at each wheel if you are getting proper current. The magnet that moves to activate the brakes in the drum will also click.
Check this thread below.
http://www.ford-trucks.com/forums/12...ontroller.html
Old 05-18-2014, 02:30 PM
msgtord's Avatar
msgtord msgtord is online now
msgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to allmsgtord is a name known to all
Have you installed the relay that's kept in the glove box?
Old 05-18-2014, 03:39 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
So you get voltage on the truck side brake pin as the controller is applied. That is good! So now work your way back from there on the trailer side. Plug in the trailer. Do you get brake voltage on the trailer wiring close to the plug? Keep testing thru the break away switch all the way to the magnets. You'll find the short eventually.
Old 05-18-2014, 06:57 PM
Mud Doc's Avatar
Mud Doc Mud Doc is offline
Mud Doc is starting off with a positive reputation.
If you place an amp meter in the line between the emergency pin and the wire to the brakes, it should read 12--about 3a for each wheel--when the pin is pulled. No amps to me would indicate there is no power from the batteries to the pin, or you have a break in the feed to the brakes. Partial amps would indicate 1 or more brakes not working.
These are maddening to trace down.
Joe
Old 05-18-2014, 07:33 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
a lot of times they run the brake wiring thru the axle. That wiring tents to get hung up and break right around the springs and such.
Quick test as referenced above is a hum at each wheel on the trailer.
Have someone step on the truck brakes and you listen at each wheel on the trailer.
Old 05-19-2014, 09:40 AM
bcontento bcontento is offline
bcontento is starting off with a positive reputation.
Quote:
Huh? Not something I am aware of.
Thanks all. I'm going to continue tracking it back from the plug.
Old 05-19-2014, 10:06 AM
senix's Avatar
relays are under the hood at the power distribution box...the big fuses. check your owners manual
Old 05-19-2014, 02:13 PM
BPofMD's Avatar
BPofMD BPofMD is offline
Posting Legend
BPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputationBPofMD has a superb reputation
That relay may no longer in the glove box as it is a 2011 truck....it's prob "new to him". You may have to get a relay from Ford (or where you bought the truck). If you don't have the OWNERS MANUAL you can get one from Ford.com - I think it is /owners. Downloadable.
Old 05-19-2014, 09:48 PM
RV_Tech's Avatar
RV_Tech RV_Tech is offline
RV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputationRV_Tech has a superb reputation
Just do this to start with. Unplug your trailer, but leave it hitched. Now with a charged battery on the trailer, pull your break away pin and try to pull the trailer. If the brakes are holding it, the problem is at the truck. If the trailer brakes are not engaged, the problem is with the trailer. Make sense?
Steve
Old 06-06-2014, 06:12 AM
jetdoc's Avatar
jetdoc jetdoc is offline
jetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud ofjetdoc has much to be proud of
Quote:
Steve
Perfect! I have disconnected the brakes from the harness and have an open circuit through the black and white wires. I guess my next step is to remove each brake at a time to find my open.....
Old 06-06-2014, 06:17 AM
senix's Avatar
Look at the rear side of the drums for the wires that need from the axle to operate the brakes. There might be one that is broken.
Old 06-06-2014, 07:59 AM
jetdoc's Avatar
I checked the drums and axles and all good. The problem was the wire through the coach to the front axle. I ran a new section of wire and now all good. Woo hoo!
Old 06-06-2014, 02:12 PM
RV_Tech's Avatar
Good to hear you got it fixed. Good job!
Steve
Old 06-07-2014, 07:16 AM
jetdoc's Avatar
Thanks! We drove a couple of hours yesterday and the brakes and controller worked great. Trailer brakes come in handy when you have to stop in a hurry.
lt green wire @ brake switch is grounded? EVERYTHING works though, BUT trailer brakes... maddmatt02 1987 - 1996 F150 & Larger F-Series Trucks 7 08-09-2015 04:23 AM
trailer brakes not working - need help Baicolt 1999 to 2016 Super Duty 2 04-22-2015 04:18 PM
Brake Controller issue... terry_opie 1999 to 2016 Super Duty 9 06-10-2012 10:59 AM
Confused with 7 pin trailer connector secolvin Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 7 09-28-2011 04:00 PM
Trailer Control Fault CampD 6.4L Power Stroke Diesel 17 12-12-2009 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
