tranny problem - Ford Truck Enthusiasts Forums
tranny problem
Old 05-18-2014, 08:48 AM
bra$$monkey's Avatar
bra$$monkey bra$$monkey is offline
bra$$monkey is starting off with a positive reputation.
tranny problem
I picked up my 2005 F150 4x4 last winter.
it has 135k miles & a slight tranny problem.
When cruising around 45 mph - right between where it wants to be in top gear or not - if I slightly accelerate the trans BANGS between the two gears.
I mean repeatedly bangs - it is not a smooth shift where it can't decide which gear to use - it is a hard BANG where it can't decide which gear to be in.
What gives? I can usually stop it if I turn on the towning button - shutting off high gear.
Old 05-19-2014, 12:01 AM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Whats the fluid look like?. Been serviced recently? I would start there. Im no trans expert but it sounds like maybe your torque converter is giving up on you.
Old 05-19-2014, 04:16 PM
twfish twfish is offline
twfish is gaining momentum as a positive member of FTE.
Are you at a lower rpm when it happens? Sounds like a coil pack
Old 05-21-2014, 02:54 PM
its not a coil pack - its certainly in the trans. It happens when cruising in OD & I slightly accelerate. Really whacks between OD & 3rd.
Old 05-21-2014, 05:46 PM
Quote:
Does it jerk or is there an actual sound? Does it do it at a higher speed or just at low rpm?
Old 05-22-2014, 11:59 AM
It makes a bang & I can feel the truck shutter & buck - it stops if I turn off the od with the towing button.
Old 05-22-2014, 10:14 PM
fordforlife1986 fordforlife1986 is offline
fordforlife1986 is starting off with a positive reputation.
hey there I am having a similar problem with my 2007 f150 and I was wondering if you ever found out what the problem was? if it was something with the tranny or coilpacks ect.
Old 05-30-2014, 04:31 PM
mchemical mchemical is offline
mchemical is starting off with a positive reputation.
Unhappy Transmission bucking around 45/50 mph
I have been having the same problem with my 2004 5.4 engine transmission for several years now. If I am traveling in that mph range I just turn off the OD.
Old 05-30-2014, 09:18 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
I bet you have a bad plug or coil. There can't be anything wrong with the trans to make it shift like that. To go from 3rd to 4th the forward clutch releases and the OD band applies. It can't happen fast enough back and forth to give a bucking sensation. You prob have a plug that has carbon tracks on the outside and when conditions are right the spark jumps to ground outside the plug instead of through the plug. Pull each coil and closely inspect inside each boot for the tracking.
Old 05-31-2014, 04:18 AM
ford-lover ford-lover is offline
ford-lover is starting off with a positive reputation.
I had the similar problem and was thinking it was tranny problem ( convertor stutter). Did the trans fluid flush. The problem continued and got worse by the week. Finally replaced all spark plugs with SP515. The problem disappeared since and is running silky smooth now. By the way, the plug change job was done by a local dealer and I was told all spark plugs came out in one piece. Lucky me!
Old 05-31-2014, 08:14 AM
Converter shudder really doesn't feel like a buck, it feels more like driving over rumble strips for a second as the torque converter clutch applies. In OPs case the truck had 135k miles when he got it so there is no telling what kind of maintenance was done or not done. Also someone could have washed the engine to make it look pretty and got water past the coil boots.
Old 06-01-2014, 12:11 PM
skunkoffroad skunkoffroad is offline
skunkoffroad is starting off with a positive reputation.
I love when people need help with something but are too much of an expert to listen to anyone.
Good luck
Old 06-01-2014, 03:28 PM
bigunit54's Avatar
bigunit54 bigunit54 is offline
bigunit54 is gaining momentum as a positive member of FTE.bigunit54 is gaining momentum as a positive member of FTE.
I was going to say it was very good advice by 70f100longbed. His advice is always spot on.
Old 06-04-2014, 05:51 PM
gijim2k1's Avatar
gijim2k1 gijim2k1 is offline
gijim2k1 is starting off with a positive reputation.
I have found the search button to be very useful on this forum.
Ford Truck Enthusiasts Forums - Search Results
changing plugs solved my problem, some have required coils too.
Old 06-04-2014, 06:14 PM
Thanks for the advice guys. I'll Change the plugs this weekend.
Sounds like everyone knows what's up.
Except for skunk - who was that comment directed at?
Code U0101 Can't communicate TCM jjlrrw Explorer, Sport Trac, Mountaineer & Aviator 10 12-01-2016 06:12 AM
Well, it wasn't the torque converter brichert General Diesel Discussion 5 06-29-2016 04:11 AM
Can't get spindle off. BroncoBilt 1978 - 1996 Big Bronco 13 11-13-2014 07:35 PM
2000 f250 tranny won't go into gears Jon paul 1999 to 2016 Super Duty 4 09-26-2014 07:38 AM
Replaced E4OD but now it's not working right. Help Please Bob 79 supercab Clutch, Transmission, Differential, Axle & Transfer Case 9 04-30-2012 09:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
