Ford truck brake controller - Ford Truck Enthusiasts Forums
Old 05-17-2014, 07:47 PM
stan'37 stan'37 is offline
stan'37 is starting off with a positive reputation.
I want to put a trailer brake controller in my 05 Ford. Does any one know if it has under dash connections for the controller. I don't see anything am I missing them? there is a plug near the back bumper. That tells me something should be up front. Any thoughts? Stan
Old 05-17-2014, 08:43 PM
paddler65 paddler65 is offline
paddler65 is starting off with a positive reputation.
hello
I have an 05 f350 with a built brake controller.
I get no voltage out of pin 4 which is the battery charging pin to the trailer on the 7 pin connector.
I do get reading at the other pins.
im doing the check with a voltmeter.
what can I check why im not getting a reading at pin 4.
thanks
Old 05-17-2014, 09:00 PM
WE3ZS's Avatar
WE3ZS WE3ZS is online now
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Quote:
On my '05 EX there was a grey plug wire tied to the dash frame up behind the radio that the patch cable from Tekonsha plugged right into then into the brake controller. My EX is more like the '04 trucks so I'm not possitive if the plug color or location was changed with the SD changes in'05.
Old 05-17-2014, 09:03 PM
WE3ZS's Avatar
World Famous Mod
Quote:
Originally Posted by paddler65 View Post
hello
thanks
You will get more attention and have a better chance of good answers if you post your question in it's own thread in either the SuperDuty forum or the Trailering Forum, trailer wiring isn't specific to the V-10.
Good luck!
Old 05-18-2014, 03:50 PM
asdrew's Avatar
asdrew asdrew is offline
asdrew is gaining momentum as a positive member of FTE.
The aftermarket brake controller connections are behind the driver's side drop down storage tray thingy and labeled. Squeeze the sides to hinge it down and dig around in there. I don't recall the specifics, but that is where I hooked up mine.
And yes, one of the other sections is a better place for info rather than this V10 area.
Old 05-18-2014, 04:18 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
hello
thanks
Make sure the key is on. There is a relay and a fuse for the BAT + for the trailer. Check those as well.
Old 05-19-2014, 10:43 AM
eberlestock's Avatar
eberlestock eberlestock is offline
eberlestock is gaining momentum as a positive member of FTE.eberlestock is gaining momentum as a positive member of FTE.
I have an 06 that has the trailer brake controller wiring sitting in the glovebox. It has a plug in connector with the wires that connect to the controller. I presume under the dash there is a factory plug that this just plugs into? My 08 F150 had this and it was simple to hook up a controller.
Old 05-19-2014, 10:53 AM
asdrew's Avatar
Yes, it gets plugged in where I was indicating behind the drop down box thingy.
Tinman52's Abondoned Vehicle Thread or, "Stan's Thread" tacomacream 1947 and Older Ford Trucks 1 02-26-2016 07:46 PM
Stan's or FPA headers abyars111 1967 - 1972 F-100 & Larger F-Series Trucks 43 10-28-2015 03:22 AM
Stans Headers...Very disappointed brandon4 1973 - 1979 F-100 & Larger F-Series Trucks 2 02-20-2015 07:33 PM
New to the forum Bullmoose C Alberta Chapter 6 11-06-2014 10:56 PM
05 ford seats stan'37 Modular V8 (4.6L, 5.4L) 2 04-11-2014 08:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
